Yannick
    1 011
Tout ce qui a été posté par Yannick
  1. Et celle là ? personne n'a encore vu ? Liste des modifications logicielles 4.530: Version 4.530 New improvements: - Added functionality of sharing gateways to other Fibaro ID users via id.cloud.fibaro.com. - Added manual user synchronization with the button in Access Control. - Added support for FIBARO Roller Shutter 3. - Added temperature displaying from the built-in sensor for FIBARO Heat Controller for version 4.5 or higher. - Added temperature sensor status displaying in the advanced configuration of FIBARO Heat Controller. - Added possibility of changing the name of your Home Center in the configuration settings. - Added assigning devices to categories for easier control in the new FIBARO Home Center mobile app. - Added assigning scenes to categories for easier control in the new FIBARO Home Center mobile app. - Added Thermostat & Heating Zone plugin, which allows to control the heating zone temperature using a physical thermostat. Resolved issues: - No notifications set in the advanced configuration of devices. - Incorrect state reporting of a blind/gate in the interface. - Mesh network reconfiguration causes delays in system operation. - Unable to add more than one empty button in a virtual device. - YR Weather plugin generates too many requests. - Empty fields in the LAN settings after switching from Static IP to DHCP. - Changing DNS and enabling remote support results in an interface error. - Notification about no compatible backups is displayed despite having them. - No auto-reboot after editing the location settings. - Incorrect redirection from the PIN code change notification. - IP camera settings tab hangs the interface. - Security fixes for remote access scripts. - Other minor fixes.
  2. Yannick
    Plugin Netatmo
    Pour ma part, je l'ai posé simplement sur le rebord en haut d'une porte à l'extérieur et, pour avoir d'autre capteur de température et d'hygrométrie à l'extérieur, les mesures sont fiables à +/- 0.2°
  3. Yannick
    Plugin Netatmo
    L'énergie est notre avenir.... économisons la !!! qui disent
  4. Yannick
    Plugin Netatmo
    Salut @Riniack Pa d'intégration de l'anémomètre Netatmo dans le plugin officiel (à moins que ça ait changé depuis ????) il faut l’intégrer avec un VD que tu trouveras ici L'original a été créé ici http://www.siio.com/energy-saving/integrating-the-netatmo-anemometer-into-the-fibaro-home-center-2-this-is-how-it-works-11973/ ça fontionne mais effectivement si ton module est mal placé... tu n'auras aucune information cohérente (c'est mon cas, je l'ai placé sur une rembarde dans mon jardin quand il y a de fortes rafales de plus de 70 km /h il m'indique allègrement du taquet à 40... il faut que je le change de place mais ma maison faisant plus de 15 m de haut... c'est chiant pour changer les piles ! Bon dév
  5. @Nico j'aime ma box et je n'utilise qu'un PC qui ne peut se connecter qu'en WIFI.... je pense que ces boules bleues sont dues à cette latence. J'essaierai un jour de me connecter avec un câble pour voir. Je suis en gigabits partout ça devrait fonctionner mieux mais bon c'est pas grave... j'aime bien le principe de bidouiller mes LUA sur mon canapé avec un petit picon.... ça fait partie du folklore et j'ai les mêmes latences sur mon autre box qui pour l'instant est totalement vierge... alors.
  6. Pour ma part j'ai mis 4 Go dans ma box. et j'ai les boules bleues au moins pendant 10 secondes à chaque changement de module ou de fenetre... j'aimerais tant que ce soit aussi rapide
  7. et d'autant plus moi qui suis commercial en infrastructure et qui vend la sécurité à mes clients (entre autre !!)
  8. Tout est rentré dans l'ordre Mais je ne sais pas ce qu'il s'est passé. Bref ça fontionne c'est le principal. Donc je ne peux vraiment pas récuéprer ma conf de ma box vers ma box 2 sans devoir réinitialiser la box 1 et sans passer par le fibaro ID ???
  9. Cool merci et pour la liste des fonctions ? pour un AVR-X4300H tu sais où les trouver ?
  10. Je viens d'envoyer la demande. Je vous tiens au courant. Merci en attendant
  11. et ben si évidemment. Je vais me rapprocher d'eux. Merci en tout cas pour le coup de paluche
  12. Ok au top @Cardanej'attends de tes nouvelles. Un lien pour le VD de @sebcbien ?
  13. Oui oui tout fonctionne parfaitement. Elles est accessible. Aucun problème de ce côté là.
  14. Toujours le même problème. Rien de changé. J'ai pourtant viré la seconde box du cloud. rien à faire toujours en connection problem
  15. Fait... Mais ça ne change rien pour la connexion au cloud de sauvegarde. Par contre ça m'a permis d'installer la 4.52. sur les 2 boxes
  16. Salut @pepite c'est bien ça mon problème et ne je comprends pas pourquoi. Mes 2 boxes sont vus sur le cloud et sont accessibles mais toutes les 2 me sortent ce message dans le menu sauvegardes et du coup je ne peux même plus lancer de mise à jour de firmware.... je comprends plus rien. Je suis bloqué en 4.512
  17. Mais si je fais ça je dois obligatoirement faire un reset complet de ma box principale c'est bien ça ? pas d'autre choix
  18. Salut à tous j'ai un souci avec mes 2 boxes, je ne peux plus lancer de mise à jour parce qu'elles n'arrivent plus à se connecter au serveur cloud. Je comprends rien
  19. Salut @pepite, lorsque je télécharge le fichier de backup et que je veux le récupérer surl'autre box, elle me renvoie une erreur "cannot decrypt backup file"
  20. Salut @Cardanenickel. Le VD pour quel ampli dis-moi ? tu l'as posté quelque part ?
  21. Salut @jojobah oui je fais comment pour récupérer le fichier de backup qui est sur le disque et plus sur la clé ?
  22. Salut @971jmd c'e'st OK ma box est repartie après un recovery et un update en passant par la 4.18. Tout est OK maintenant, je veux transférer ma conf de la box A vers la B. Je sais que certains l'ont fait mais je ne sais plus où je trouve ça. J'ai déjà fait une demande sur le topic du Firmware 4.512 mais pas de réponse pour le mement. Tu sais ? Merci
  23. Salut @Daktari59 Je veux basculer ma plus vieille box en box de test et utiliser la nouvelle en principal.... Comme beaucoup d'entre nous sur le forum le font. et surtout pour basculer rapidement sur la box qui restera debout en cas de défaillance de l'une d'elle. tu connais le WAF ? et ben le jour où ma box s'arrête, je peux faire mes valises ! Elles sont toutes 2 en IP statiques et dans le home.fiibaro.com, les 2 boxes sont bien vues. sans problème.
  24. J'ai un autre souci sur mes backup. Je n'artrive plus ni sur la box principale ni sur la secours à accéder au backup cloud Alors que mes boxes sont biens toutes les 2 connectés et accessibles depuis l'extérieur... Un idée ?
  25. salut salut la compagnie, je cherche l'endroit où l'un de vous parlait d'une copie de la conf d'une HC2 vers une autre HC2. Mais je ne veux pas faire une migration comme proposée par fibaro où après le transfert l'ancienne est totalement reset. Vous pourriez me dire comment je fais sachant que mes 2 HC2 sont en 4.512. Merci
