angelz
70 -
Tout ce qui a été posté par angelz
Bonjour, j'utilise ce script depuis quelque semaine et ca marche bien sauf que j'ai des fausse detection j'aimerais dire au script : si une detection de mouvement, attendre 1 seconde ou plus et reverifier si il y a toujours une detection et seulement la allumer la lampe mais je ne vois pas comment faire. voici mon code : --[[ %% properties 65 value 79 value %% globals TimeOfDay PresentState --]] --[[ Change - XXX value - above. One for motion sensor, one for Light sensor. TimeOfDay global variable and lux make sure that the scene will be triggered when you are already in the room and something changes. Set your settings below, lights and add extra functions Feel free to suggest changes or contact when having problems. It is not allowed to sell or distribute this software and earlier versions without the approval of Control Living © 2014 - 2015 Smart lights by Control Living Version 1.6.7 --]] -------------------------------------------------------------------- -----------------------YOUR LIGHT SETTINGS-------------------------- motionSensorID = {65}; -- change id for your motion sensor. LuxSensorID = {79}; -- change id for your light sensor. actionDevice = 100; -- change id for your light sensor. --Enter the name of your Global variable. WITHOUT IT, THE SCENE DOES NOT WORK. Capital sensitive! sleepState = "SleepState"; --Sleep globalstate variable. timeOfDay = "TimeOfDay"; --Time of Day Global variable. presentState = "PresentState"; --Present state Global variable. --Enter the values of your global variables stated above. If not using, copy the name in front of the "YourValueName" sleepStateMapping = {Sleeping="Sleeping", Awake="Awake"}; timeOfDayMapping = {Morning="Morning", Day="Day", Evening="Evening", Night="Night"}; presentStateMapping = {Home="Home", Away="Away", Holiday="Holiday"}; -- Set the lux value for which the lights have to be turned on. -- If you don't want to use the MinLux then just set it to: 65535 minLuxMorning = 2500; minLuxDay = 2500; minLuxEvening = 2500; minLuxNight = 2500; --If the current lux value is above the maxlux, the lights will turn off after their set onTime. maxLuxMorning = 6000; maxLuxDay = 6000; --[[ Now the most important part: Here you can enter what light, for how long and at what value has to be turned on. Leave empty brackets for no lights. To set the light value without timer use 2 parameters: {id=LightID, setValue="VALUE"} To set the light value with timer use 3 parameters: {id=LightID, setValue="VALUE", onTime=timeInSeconds } To set the light value for RGBW: use the above, where setValue is: setValue={R="255",G="255",B="255",W="255"} -- RGBW set: {id=LightID, setValue={R="255",G="255",B="255",W="255"}, onTime=timeInSeconds } --]] lightsSleeping = {}; --lights that are triggered when Sleepstate is sleeping. lightsMorning = {{id=actionDevice, setValue="turnOn", onTime=20}}; lightsDay = {{id=actionDevice, setValue="turnOn", onTime=20}}; lightsEvening = {{id=actionDevice, setValue="turnOn", onTime=20}}; lightsNight = {{id=actionDevice, setValue="turnOn", onTime=20}}; --Manual Override, the time that lights will not be turned ON again after manually turning them off. OverrideFor = 90; dimmDownTime = 10; -------------------------------------------------------------------- -------------------------EXTRA FEATURES----------------------------- extraMorningFunc = function() -- Add your extra code here. If you want some checks or maybe run a virtual device button. --This code is always triggered if there is motion. -- movieLights = {{180, "10"},{181, "10"} }; --if (xbmc == "playing" ) then CallLightArray(movieLights); ExtraDebug("Extra morning function called"); end extraDayFunc = function() -- Add your extra code here. If you want some checks or maybe run a virtual device button. --This code is always triggered if there is motion. ExtraDebug("Extra day function called"); end extraEveningFunc = function() -- Add your extra code here. If you want some checks or maybe run a virtual device button. --This code is always triggered if there is motion. ExtraDebug("Extra evening function called"); end extraNightFunc = function() -- Add your extra code here. If you want some checks or maybe run a virtual device button. --This code is always triggered if there is motion. ExtraDebug("Extra night function called"); end extraLightTriggerChecks = function() --add extra checks here. and return the total true or false value. --if returning false the lights will not be triggered. -- for instance: return ( (pcTurnedOff == true ) and (xbmc ~= "Empty") ); -- return true to enable lights to turn on return true; end extraOffChecks = function() --return true to keep lights on. return false; end -------------------------------------------------------------------- ----------------------ADVANCES SETTINGS----------------------------- local showStandardDebugInfo = true; -- Debug shown in white local showExtraDebugInfo = false; -- Debug shown in orange -------------------------------------------------------------------- -------------------------------------------------------------------- -- DO NOT CHANGE THE CODE BELOW -- -------------------------------------------------------------------- --UPDATE FROM HERE --private variables startSource = fibaro:getSourceTrigger(); keepLightsOn = false; timerRunning = false; previousLights = nil; version = "1.6.7"; SavedState = { homeStatus = "", sleepState = 0, timeOfDay = "", lux = 0, motion = 0, startTime = 0 } CurrentState = { homeStatus = "", sleepState = "", timeOfDay = "", lux = 0, motionState = 0, currentLightArray = {} } RGBWDeviceType = { "com.fibaro.RGBW", "com.fibaro.colorController", "com.fibaro.FGRGBW441M" } BinaryDeviceType = { "com.fibaro.binarySwitch","com.fibaro.FGWP101", "com.fibaro.developer.angelz.SwitchLumiereFhem", "turnOn" } DimmerDeviceType = { "com.fibaro.multilevelSwitch" } OffModes = {None, ByScene, ManualOverride } function Debug( color, message ) fibaro:debug(string.format('<%s style="color:%s;">%s</%s>', "span", color, message, "span")); end --Making sure that only one instance of the scene is running. fibaro:sleep(50); --sleep to prevent all instances being killed. if (fibaro:countScenes() > 1) then if (showExtraDebugInfo) then Debug( "grey", "Abort, Scene count = " .. fibaro:countScenes()); end fibaro:abort(); end --------------------------EXECUTION---------------------------------- function SetCurrentStatus() ExtraDebug("Updating current variable statuses"); CurrentState.homeStatus = GetPresentState(); CurrentState.timeOfDay = GetTimeOfDay(); CurrentState.sleepState = GetSleepState(); CurrentState.lux = GetAverageLuxValue(); CurrentState.motionState = GetCurrentMotionStatus(); end function SaveCurrentStatus() ExtraDebug("Saving current variable statuses"); SavedState.homeStatus = CurrentState.homeStatus; SavedState.timeOfDay = CurrentState.timeOfDay; SavedState.sleepState = CurrentState.sleepState; SavedState.lux = CurrentState.lux; SavedState.motion = CurrentState.motionState; end function CheckStatusChanges() ExtraDebug("Status change check"); if (CurrentState.homeStatus ~= SavedState.homeStatus ) or (CurrentState.timeOfDay ~= SavedState.timeOfDay ) then if (CurrentState.homeStatus ~= presentStateMapping.Home ) then TurnOffLights(); else SceneTriggered(); --reset time. end; end SaveCurrentStatus(); -- if we still have a motion then reset timer. if ( (CurrentState.motionState ~= 0 or extraOffChecks() ) and not IsMaxLuxExceeded() ) then ExtraDebug( "Resetting time" ); SavedState.startTime = os.time(); else ExtraDebug("Timer is not reset."); end --any other case, we are not resetting the timer. end function IsMaxLuxExceeded() if (CurrentState.timeOfDay == timeOfDayMapping.Morning and CurrentState.lux > maxLuxMorning ) then ExtraDebug( "Current lux value: " .. CurrentState.lux .. " higher then max Lux Morning: " .. maxLuxMorning .. "."); return true; elseif (CurrentState.timeOfDay == timeOfDayMapping.Day and CurrentState.lux > maxLuxDay ) then ExtraDebug( "Current lux value: " .. CurrentState.lux .. " higher then max Lux Day: " .. maxLuxDay .. "."); return true; end return false; end function LightsOff( lightArray ) local stillLightsOn = 0; local currentTime = os.time(); for i = 1,#lightArray do if ( lightArray[i].onTime ~= nil) then lightItem = lightArray[i]; lightItem.OffMode = CheckManualOverrideItem( lightItem ); --local if ( lightItem.OffMode == "ManualOverride" ) then ExtraDebug("Manual override for light: [" .. lightItem.id .. "]" .. lightItem.name .. " active, not turning on"); goto continue; end --On till: local timeL = SavedState.startTime + (lightItem.onTime); local timeLeft = timeL - currentTime; if (timeLeft >= 0 ) then ExtraDebug("Time left for: [" .. lightItem.id .. "]" .. lightItem.name .. ": " .. timeLeft .. " seconds" ); end if ( timeLeft < dimmDownTime ) then if ( lightItem.OffMode ~= "ManualOverride" ) then lightItem.OffMode = "ByScene"; end if ( (timeLeft <= 0) and (lightItem.currentValue ~= 0) ) then fibaro:call(lightItem.id, "turnOff"); StandardDebug("Switch off light: [" .. lightItem.id .. "]'" .. lightItem.name .."'"); else if ( item.lightType == "com.fibaro.multilevelSwitch" ) then currentValueDiv = roundit(((lightItem.currentValue) / (dimmDownTime)), 0); currentValueNew = (lightItem.currentValue - currentValueDiv); if (currentValueNew <=0 ) then currentValueNew = 0; end fibaro:call(lightItem.id, "setValue", tostring(currentValueNew)); end stillLightsOn = stillLightsOn + 1; end elseif (CheckLightToBeTurnedOnAgain(lightItem)) then ExtraDebug("Turn light: " .. lightItem.id .. " back on"); turnLightOn(lightItem); lightItem.OffMode = ""; stillLightsOn = stillLightsOn + 1; else lightItem.OffMode = "NoOverride"; stillLightsOn = stillLightsOn + 1; end end ::continue:: end return stillLightsOn; end function KeepLightsOnTimer() ExtraDebug("--------------- Timer running ---------------"); ExtraDebug("starting with while loop, to keep lights on"); SavedState.startTime = os.time(); SaveCurrentStatus(); sleepTime = 1000; while ( keepLightsOn ) do ExtraDebug("--------------- next timer run ---------------"); fibaro:sleep(sleepTime); start_time = os.clock(); SetCurrentStatus(); currentLightArray = GetTimeOfDayLightArray(); UpdateLightValues(currentLightArray); CheckStatusChanges(); local stillLightsOn = 0; stillLightsOn = LightsOff( currentLightArray ); if (stillLightsOn == 0 ) then keepLightsOn = RunManualOverrideMode( currentLightArray ); end_time = 0; --if lights turned back on after override. else end_time = os.clock() end elapsed_time = (end_time - start_time) * 1000; sleepTime = 1000 - elapsed_time; end end function CheckManualOverrideItem( currentItem ) --ExtraDebug("Manual override check for: [" .. currentItem.id .. "]" .. currentItem.name); --fibaro:debug(currentItem.currentValue) --fibaro:debug(currentItem.OffMode) if (currentItem.currentValue == 0 and currentItem.OffMode ~= "ByScene" ) then ExtraDebug( "Manual override for light: [" .. currentItem.id .. "]" .. currentItem.name .. " active" ); return "ManualOverride"; elseif (currentItem.currentValue ~= 0 and currentItem.OffMode == "ManualOverride" ) then ExtraDebug( "Manual override for light: [" .. currentItem.id .. "]" .. currentItem.name .. " cancelled" ); return "NoOverride"; end return currentItem.OffMode; --returning current mode; end function RunManualOverrideMode( currentLightArray ) OverrideForAll = CheckIfAllInOverrideMode(currentLightArray); if ( OverrideForAll ) then ExtraDebug("-----------------Override Mode---------------"); OverrideTimer = os.time(); while ( OverrideForAll and (OverrideTimer + OverrideFor ) - os.time() > 0 ) do ExtraDebug("Still in override for: " .. (OverrideTimer + OverrideFor ) - os.time() .. " seconds" ); fibaro:sleep(1000); UpdateLightValues(currentLightArray); OverrideForAll = CheckIfAllInOverrideMode(currentLightArray); motion = GetCurrentMotionStatus(); if ( motion ~= 0 ) then OverrideTimer = os.time(); end end else return false; end -- if ( (OverrideTimer + OverrideFor ) - os.time() <= 0 ) then --time has end. So not continue to run lights loop -- return false; -- end if (OverrideForAll) then return false; --run lights else return true; end end function CheckIfAllInOverrideMode(currentLightArray) OverrideForAll = 0; for i = 1,#currentLightArray do if ( CheckManualOverrideItem(currentLightArray[i]) == "ManualOverride" ) then OverrideForAll = OverrideForAll +1; else return false; end end if ( OverrideForAll ~= 0 and OverrideForAll == #currentLightArray ) then return true; end return false; end function RunTimer() if ( keepLightsOn and not timerRunning ) then ExtraDebug("Starting timer, not yet running"); timerRunning = true; KeepLightsOnTimer(); else ExtraDebug("Timer already running, returning"); end end function TurnOffLights() local timeOfDayArray = GetTimeOfDayLightArray(); SetLightValues(timeOfDayArray); UpdateLightValues(timeOfDayArray); CallLightArray(timeOfDayArray, "off" ); return; end ----------------------Turn lights on functions------------------------ function CallLightArray( lightArray, turnOnOrOff ) if (#lightArray == 0 ) then if (CurrentState.sleepState == sleepStateMapping.Sleeping) then noLightsSetText = "lightsSleeping"; else noLightsSetText = CurrentState.timeOfDay; end StandardDebug( "No lights set for " .. noLightsSetText ); return; end if not ( CheckIfTable(lightArray, "lights" .. CurrentState.timeOfDay ) ) then return end for i = 1,#lightArray do if not ( CheckIfTable(lightArray[i], "lights" .. CurrentState.timeOfDay ) ) then break end lightItem = lightArray[i]; if (turnOnOrOff == "on" ) then turnLightOn(lightItem); if (lightItem.onTime ~= nil) then keepLightsOn = true; end else fibaro:call(lightItem.id, "turnOff"); --Always turn off, if HC2 light status is not actual. if ( lightItem.currentValue ~= 0) then keepLightsOn = false; StandardDebug("Switch off light: [" .. lightItem.id .. "]'" .. lightItem.name .."'"); end end end StandardDebug( "Lights turned: " .. turnOnOrOff .. " for " .. CurrentState.timeOfDay ); end function turnLightOn( lightItem ) if (lightItem.lightType == "com.fibaro.multilevelSwitch" ) then fibaro:call(lightItem.id, "setValue", tostring(lightItem.setValue)); StandardDebug( "Set: [" .. lightItem.id .. "]'" .. lightItem.name .. "' to Value: " .. lightItem.setValue ); elseif ( lightItem.lightType == "com.fibaro.RGBW" )then StandardDebug( "Turn: [" .. lightItem.id .. "]'" .. lightItem.name .. "' On"); if ( lightItem.setValue.brg~= nil ) then fibaro:call(lightItem.id, "setBrightness", tostring(lightItem.setValue.brg)); else local clrvalues =lightItem.setValue; fibaro:call(lightItem.id, "setColor", clrvalues.R, clrvalues.G, clrvalues.B, clrvalues.W) end elseif (lightItem.lightType == "com.fibaro.binarySwitch") then fibaro:call(lightItem.id, "turnOn"); StandardDebug( "Turn: [" .. lightItem.id .. "]'" .. lightItem.name .. "' On"); end end function CheckPreviousLights( NewLightArray ) if ( previousLights ~= nil ) then for i = 1,#previousLights do local lightItem = previousLights[i]; for i = 1,#NewLightArray do local lightItem1 = NewLightArray[i]; inarray = false; if ( lightItem.id == lightItem1.id ) then inarray= true; break end end if not ( inarray ) then fibaro:call(lightItem.id, "turnOff"); end end end previousLights = NewLightArray; end function LightperDayPart( minLux, lightArray ) local newLuxValue = CurrentState.lux; if ( extraLightTriggerChecks() ) then if ( newLuxValue > minLux ) then StandardDebug( "Sensor lux: " .. newLuxValue .. " higher then minValue: " .. minLux .. " : no action"); else StandardDebug("Sensor lux: " .. newLuxValue .. " is lower then minValue: " .. minLux); SetLightValues(lightArray); CallLightArray( lightArray, "on" ); CheckPreviousLights( lightArray ); end else ExtraDebug("ExtraLightTriggerChecks failed, so no lights"); end end function SceneTriggered() if ( CurrentState.homeStatus ~= presentStateMapping.Home ) then ExtraDebug("Presentstate = not at home, so no lights"); elseif ( CurrentState.sleepState == sleepStateMapping.Sleeping ) then LightperDayPart( 65535, lightsSleeping ); elseif ( CurrentState.timeOfDay == timeOfDayMapping.Morning ) then extraMorningFunc(); LightperDayPart( minLuxMorning, lightsMorning ); elseif ( CurrentState.timeOfDay == timeOfDayMapping.Day ) then extraDayFunc(); LightperDayPart( minLuxDay, lightsDay ); elseif ( CurrentState.timeOfDay == timeOfDayMapping.Evening ) then extraEveningFunc(); LightperDayPart( minLuxEvening, lightsEvening ); elseif ( CurrentState.timeOfDay == timeOfDayMapping.Night ) then extraNightFunc(); LightperDayPart( minLuxNight, lightsNight ); else ErrorDebug( "No lights: " .. CurrentState.timeOfDay ); end if (keepLightsOn == true) then RunTimer(); end end function SceneTriggeredByLights( st ) if (st == "off") then ExtraDebug( "light turned off, sleep 4 sec" ); fibaro:sleep(4000); elseif (st == "on") then ExtraDebug( "light turned on, activating timer" ); fibaro:sleep(4000); --TODO: add light to current array. --keepLightsOn = true; --RunTimer(); end end ------------------------STATUS functions------------------------------ function GetTimeOfDay() return LookupGlobal( timeOfDay, "TimeOfDay", "Day"); end function GetSleepState() return LookupGlobal( sleepState, "sleepState", "Awake"); end function GetPresentState() return LookupGlobal( presentState, "presentState", "Home"); end function LookupGlobal( name, stateName, default ) local ps = fibaro:getGlobalValue( name ); if ( (ps ~= "") and (ps ~= nil ) ) then ExtraDebug("returned " .. stateName .. ": " .. ps ); return ps; else ErrorDebug( stateName .. " variable not found"); return default; end end function lightsStatus( id ) --check if lights are already on. allLights = {lightsSleeping, lightsMorning, lightsDay, lightsEvening, lightsNight }; for i = 1,#allLights do for iL = 1, #allLights[i] do local lightItem = allLights[i][iL]; if ( lightItem.id == tonumber(id) ) then if ( lightItem.currentValue == 0 ) then return "off"; else return "on"; end end end end ErrorDebug("Light status unknown"); return "Unknown"; end function GetTimeOfDayLightArray() if ( CurrentState.sleepState == sleepStateMapping.Sleeping ) then return lightsSleeping; elseif ( CurrentState.timeOfDay == timeOfDayMapping.Morning ) then return lightsMorning; elseif ( CurrentState.timeOfDay == timeOfDayMapping.Day ) then return lightsDay; elseif ( CurrentState.timeOfDay == timeOfDayMapping.Evening ) then return lightsEvening; elseif ( CurrentState.timeOfDay == timeOfDayMapping.Night ) then return lightsNight; end end function GetCurrentMotionStatus() local sensorbreached = 0; if (CheckIfTable(motionSensorID, "motionSensorID") ) then for i = 1,#motionSensorID do if ( tonumber(fibaro:getValue(motionSensorID[i], "value")) > 0 ) then sensorbreached = 1; end end else --if not a table, just return the value of the containing ID sensorbreached = tonumber(fibaro:getValue(motionSensorID, "value")) end return sensorbreached; end function GetAverageLuxValue() local luxAverage = 0; if (CheckIfTable(LuxSensorID, "LuxSensorID") ) then if (#LuxSensorID == 1) then return tonumber(fibaro:getValue(LuxSensorID[1], "value")); end for i = 1,#LuxSensorID do luxAverage = luxAverage + tonumber(fibaro:getValue(LuxSensorID[i], "value")); end luxAverage = roundit( (luxAverage / #LuxSensorID), 0 ); else --if not a table, just return the value of the containing ID luxAverage = tonumber(fibaro:getValue(LuxSensorID, "value")); end return luxAverage; end function UpdateLightValues( currentArray ) for i = 1,#currentArray do item = currentArray[i]; newValue = fibaro:getValue(item.id, "value"); item.currentValue = tonumber(newValue) ~= nil and tonumber(newValue) or ( newValue == "true" and 1 or 0 ); if ( item.lightType == "com.fibaro.RGBW" )then color = fibaro:getValue(item.id, "color"); c = {R="0", G="0", B="0", W="0", brg="0" } c.R, c.G, c.B, c.W = color:match("([^,]+),([^,]+),([^,]+),([^,]+)"); c.brg = fibaro:getValue(item.id, "brightness"); item.currentValue = c; end end end function SetLightValues(currentArray) for i = 1,#currentArray do item = currentArray[i]; item.name = tostring(fibaro:getName(item.id)); item.OffMode = "NoOverride"; if (item.name == nil) then item.name = "Unknown"; end item.lightType = GetDeviceType( item.id ); end end function GetDeviceType(itemId) deviceType = fibaro:getType(item.id); if ( idIsInList(deviceType, RGBWDeviceType) ) then deviceType ="com.fibaro.RGBW"; elseif ( idIsInList(deviceType, BinaryDeviceType) ) then deviceType = "com.fibaro.binarySwitch"; elseif ( idIsInList(deviceType, DimmerDeviceType ) ) then deviceType = "com.fibaro.multilevelSwitch"; --elseif( ) then --deviceType = "Philips.Hue"; end return deviceType; end --------------------Helper functions-------------------------------- function CheckLightToBeTurnedOnAgain(lightItem) if not (lightItem.OffMode=="ByScene") then return; end if (lightItem.lightType == "com.fibaro.multilevelSwitch" ) then if (lightItem.currentValue) < tonumber(lightItem.setValue) then return true; end elseif( lightItem.lightType == "com.fibaro.RGBW" )then c = lightItem.currentValue; if (c.R == "0" and c.G == "0" and c.B == "0" and c.W == "0" ) then return true; end elseif (lightItem.lightType == "com.fibaro.binarySwitch") then if (lightItem.setValue == "turnOn" and lightItem.currentValue == 0 ) then return true; end end return false; end function CheckIfTable( array, arrayname ) local tableCheck = tostring( type( array ) ); if ( tableCheck ~= "table" ) then ErrorDebug("Missing brackets for variable: '" .. arrayname .. "', please place extra brackts: { } around: " .. array .. "."); return false; end return true; end function roundit(num, idp) local mult = 10^(idp or 0) return math.floor(num * mult + 0.5) / mult end function idIsInList( startSourceId, sensorList ) for i = 1,#sensorList do if ( startSourceId == sensorList[i] ) then return true; end end return false; end --------------------Debugging Functions----------------------------- function StandardDebug( debugMessage ) if ( showStandardDebugInfo ) then Debug( "white", debugMessage); end end function ExtraDebug( debugMessage ) if ( showExtraDebugInfo ) then Debug( "orange", debugMessage); end end function ErrorDebug( debugMessage ) Debug( "red", "Error: " .. debugMessage); Debug( "red", ""); end function TestDebug(debugMessage ) Debug( "blue", "Testing: " .. debugMessage ); end ----------------------START OF THE SCENE---------------------------- SetCurrentStatus(); StandardDebug("Home status: " .. CurrentState.homeStatus ); StandardDebug("Motion status: " .. ( CurrentState.motionState == 0 and "No movement" or "movement")); if (startSource["type"] == "property") then startSourceID = tonumber(startSource['deviceID']); triggerDebug = "Triggered by: " .. startSourceID; if ( idIsInList( startSourceID, motionSensorID ) ) then StandardDebug( triggerDebug .. " Motion sensor" ); if ( CurrentState.motionState > 0 ) then SceneTriggered(); end elseif ( idIsInList( startSourceID, LuxSensorID ) ) then StandardDebug( triggerDebug .. " Lux sensor" ); ExtraDebug( "Lux value changed to: " .. CurrentState.lux ); if ( CurrentState.motionState > 0 ) then SceneTriggered(); end else StandardDebug( triggerDebug .. " Light switch" ); st = lightsStatus( startSourceID ); if (st == "Unknown") then ErrorDebug( "Unknown light trigger" ); else SceneTriggeredByLights( st ); end -- Maybe we can change the light preset to make it more intelligent. -- Maybe we can change the Lux preset to make it more intelligent. end elseif ( startSource["type"] == "global" ) then StandardDebug( "Triggered by: " .. "global variable" ); -- If home status away, we trigger so the current array will be turned off. If motion, turn them on. if (CurrentState.homeStatus ~= presentStateMapping.Home) then TurnOffLights(); elseif (CurrentState.motionState > 0 ) then SceneTriggered(); end else StandardDebug( "Triggered by: " .. startSource["type"] .. " , Not checking the motion state." ); --Just run the Light Code, not checking for motion. Probably triggered manually. if ( startSource["type"] == "other" ) then SceneTriggered(); end end Debug( "green", "© Smart Lights V" .. version .. " | by Control Living, Finished" ); Debug( "green", "-------------------------------------------------------" ); --fibaro:abort(); --otherwise scene will stay alive to long. --UPDATE TILL HERE si quelqu'un a une idée ? merci
- 171 réponses
- Smart Lights
- motion sensor
bonjour, voila j'utilise ce script depuis quelques semaines et c'est vrai qu'il est pas mal :-) par contre je ne vois pas comment (et si c'est possible) que la détection se fasse sur X sec et pas a chaque détection en fait pour ma monté d'escalier les lumière s'allume trop souvent j'aimerais dire au script si détection de mouvement et que 2 sec plus tard il y a toujours une détection la lampe s'allume voici mon script : --[[ %% properties 65 value 79 value %% globals TimeOfDay PresentState --]] --[[ Change - XXX value - above. One for motion sensor, one for Light sensor. TimeOfDay global variable and lux make sure that the scene will be triggered when you are already in the room and something changes. Set your settings below, lights and add extra functions Feel free to suggest changes or contact when having problems. It is not allowed to sell or distribute this software and earlier versions without the approval of Control Living © 2014 - 2015 Smart lights by Control Living Version 1.6.7 --]] -------------------------------------------------------------------- -----------------------YOUR LIGHT SETTINGS-------------------------- motionSensorID = {65}; -- change id for your motion sensor. LuxSensorID = {79}; -- change id for your light sensor. actionDevice = 100; -- change id for your light sensor. --Enter the name of your Global variable. WITHOUT IT, THE SCENE DOES NOT WORK. Capital sensitive! sleepState = "SleepState"; --Sleep globalstate variable. timeOfDay = "TimeOfDay"; --Time of Day Global variable. presentState = "PresentState"; --Present state Global variable. --Enter the values of your global variables stated above. If not using, copy the name in front of the "YourValueName" sleepStateMapping = {Sleeping="Sleeping", Awake="Awake"}; timeOfDayMapping = {Morning="Morning", Day="Day", Evening="Evening", Night="Night"}; presentStateMapping = {Home="Home", Away="Away", Holiday="Holiday"}; -- Set the lux value for which the lights have to be turned on. -- If you don't want to use the MinLux then just set it to: 65535 minLuxMorning = 2500; minLuxDay = 2500; minLuxEvening = 2500; minLuxNight = 2500; --If the current lux value is above the maxlux, the lights will turn off after their set onTime. maxLuxMorning = 6000; maxLuxDay = 6000; --[[ Now the most important part: Here you can enter what light, for how long and at what value has to be turned on. Leave empty brackets for no lights. To set the light value without timer use 2 parameters: {id=LightID, setValue="VALUE"} To set the light value with timer use 3 parameters: {id=LightID, setValue="VALUE", onTime=timeInSeconds } To set the light value for RGBW: use the above, where setValue is: setValue={R="255",G="255",B="255",W="255"} -- RGBW set: {id=LightID, setValue={R="255",G="255",B="255",W="255"}, onTime=timeInSeconds } --]] lightsSleeping = {}; --lights that are triggered when Sleepstate is sleeping. lightsMorning = {{id=actionDevice, setValue="turnOn", onTime=20}}; lightsDay = {{id=actionDevice, setValue="turnOn", onTime=20}}; lightsEvening = {{id=actionDevice, setValue="turnOn", onTime=20}}; lightsNight = {{id=actionDevice, setValue="turnOn", onTime=20}}; --Manual Override, the time that lights will not be turned ON again after manually turning them off. OverrideFor = 90; dimmDownTime = 10; -------------------------------------------------------------------- -------------------------EXTRA FEATURES----------------------------- extraMorningFunc = function() -- Add your extra code here. If you want some checks or maybe run a virtual device button. --This code is always triggered if there is motion. -- movieLights = {{180, "10"},{181, "10"} }; --if (xbmc == "playing" ) then CallLightArray(movieLights); ExtraDebug("Extra morning function called"); end extraDayFunc = function() -- Add your extra code here. If you want some checks or maybe run a virtual device button. --This code is always triggered if there is motion. ExtraDebug("Extra day function called"); end extraEveningFunc = function() -- Add your extra code here. If you want some checks or maybe run a virtual device button. --This code is always triggered if there is motion. ExtraDebug("Extra evening function called"); end extraNightFunc = function() -- Add your extra code here. If you want some checks or maybe run a virtual device button. --This code is always triggered if there is motion. ExtraDebug("Extra night function called"); end extraLightTriggerChecks = function() --add extra checks here. and return the total true or false value. --if returning false the lights will not be triggered. -- for instance: return ( (pcTurnedOff == true ) and (xbmc ~= "Empty") ); -- return true to enable lights to turn on return true; end extraOffChecks = function() --return true to keep lights on. return false; end -------------------------------------------------------------------- ----------------------ADVANCES SETTINGS----------------------------- local showStandardDebugInfo = true; -- Debug shown in white local showExtraDebugInfo = false; -- Debug shown in orange -------------------------------------------------------------------- -------------------------------------------------------------------- -- DO NOT CHANGE THE CODE BELOW -- -------------------------------------------------------------------- --UPDATE FROM HERE --private variables startSource = fibaro:getSourceTrigger(); keepLightsOn = false; timerRunning = false; previousLights = nil; version = "1.6.7"; SavedState = { homeStatus = "", sleepState = 0, timeOfDay = "", lux = 0, motion = 0, startTime = 0 } CurrentState = { homeStatus = "", sleepState = "", timeOfDay = "", lux = 0, motionState = 0, currentLightArray = {} } RGBWDeviceType = { "com.fibaro.RGBW", "com.fibaro.colorController", "com.fibaro.FGRGBW441M" } BinaryDeviceType = { "com.fibaro.binarySwitch","com.fibaro.FGWP101", "com.fibaro.developer.angelz.SwitchLumiereFhem", "turnOn" } DimmerDeviceType = { "com.fibaro.multilevelSwitch" } OffModes = {None, ByScene, ManualOverride } function Debug( color, message ) fibaro:debug(string.format('<%s style="color:%s;">%s</%s>', "span", color, message, "span")); end --Making sure that only one instance of the scene is running. fibaro:sleep(50); --sleep to prevent all instances being killed. if (fibaro:countScenes() > 1) then if (showExtraDebugInfo) then Debug( "grey", "Abort, Scene count = " .. fibaro:countScenes()); end fibaro:abort(); end --------------------------EXECUTION---------------------------------- function SetCurrentStatus() ExtraDebug("Updating current variable statuses"); CurrentState.homeStatus = GetPresentState(); CurrentState.timeOfDay = GetTimeOfDay(); CurrentState.sleepState = GetSleepState(); CurrentState.lux = GetAverageLuxValue(); CurrentState.motionState = GetCurrentMotionStatus(); end function SaveCurrentStatus() ExtraDebug("Saving current variable statuses"); SavedState.homeStatus = CurrentState.homeStatus; SavedState.timeOfDay = CurrentState.timeOfDay; SavedState.sleepState = CurrentState.sleepState; SavedState.lux = CurrentState.lux; SavedState.motion = CurrentState.motionState; end function CheckStatusChanges() ExtraDebug("Status change check"); if (CurrentState.homeStatus ~= SavedState.homeStatus ) or (CurrentState.timeOfDay ~= SavedState.timeOfDay ) then if (CurrentState.homeStatus ~= presentStateMapping.Home ) then TurnOffLights(); else SceneTriggered(); --reset time. end; end SaveCurrentStatus(); -- if we still have a motion then reset timer. if ( (CurrentState.motionState ~= 0 or extraOffChecks() ) and not IsMaxLuxExceeded() ) then ExtraDebug( "Resetting time" ); SavedState.startTime = os.time(); else ExtraDebug("Timer is not reset."); end --any other case, we are not resetting the timer. end function IsMaxLuxExceeded() if (CurrentState.timeOfDay == timeOfDayMapping.Morning and CurrentState.lux > maxLuxMorning ) then ExtraDebug( "Current lux value: " .. CurrentState.lux .. " higher then max Lux Morning: " .. maxLuxMorning .. "."); return true; elseif (CurrentState.timeOfDay == timeOfDayMapping.Day and CurrentState.lux > maxLuxDay ) then ExtraDebug( "Current lux value: " .. CurrentState.lux .. " higher then max Lux Day: " .. maxLuxDay .. "."); return true; end return false; end function LightsOff( lightArray ) local stillLightsOn = 0; local currentTime = os.time(); for i = 1,#lightArray do if ( lightArray[i].onTime ~= nil) then lightItem = lightArray[i]; lightItem.OffMode = CheckManualOverrideItem( lightItem ); --local if ( lightItem.OffMode == "ManualOverride" ) then ExtraDebug("Manual override for light: [" .. lightItem.id .. "]" .. lightItem.name .. " active, not turning on"); goto continue; end --On till: local timeL = SavedState.startTime + (lightItem.onTime); local timeLeft = timeL - currentTime; if (timeLeft >= 0 ) then ExtraDebug("Time left for: [" .. lightItem.id .. "]" .. lightItem.name .. ": " .. timeLeft .. " seconds" ); end if ( timeLeft < dimmDownTime ) then if ( lightItem.OffMode ~= "ManualOverride" ) then lightItem.OffMode = "ByScene"; end if ( (timeLeft <= 0) and (lightItem.currentValue ~= 0) ) then fibaro:call(lightItem.id, "turnOff"); StandardDebug("Switch off light: [" .. lightItem.id .. "]'" .. lightItem.name .."'"); else if ( item.lightType == "com.fibaro.multilevelSwitch" ) then currentValueDiv = roundit(((lightItem.currentValue) / (dimmDownTime)), 0); currentValueNew = (lightItem.currentValue - currentValueDiv); if (currentValueNew <=0 ) then currentValueNew = 0; end fibaro:call(lightItem.id, "setValue", tostring(currentValueNew)); end stillLightsOn = stillLightsOn + 1; end elseif (CheckLightToBeTurnedOnAgain(lightItem)) then ExtraDebug("Turn light: " .. lightItem.id .. " back on"); turnLightOn(lightItem); lightItem.OffMode = ""; stillLightsOn = stillLightsOn + 1; else lightItem.OffMode = "NoOverride"; stillLightsOn = stillLightsOn + 1; end end ::continue:: end return stillLightsOn; end function KeepLightsOnTimer() ExtraDebug("--------------- Timer running ---------------"); ExtraDebug("starting with while loop, to keep lights on"); SavedState.startTime = os.time(); SaveCurrentStatus(); sleepTime = 1000; while ( keepLightsOn ) do ExtraDebug("--------------- next timer run ---------------"); fibaro:sleep(sleepTime); start_time = os.clock(); SetCurrentStatus(); currentLightArray = GetTimeOfDayLightArray(); UpdateLightValues(currentLightArray); CheckStatusChanges(); local stillLightsOn = 0; stillLightsOn = LightsOff( currentLightArray ); if (stillLightsOn == 0 ) then keepLightsOn = RunManualOverrideMode( currentLightArray ); end_time = 0; --if lights turned back on after override. else end_time = os.clock() end elapsed_time = (end_time - start_time) * 1000; sleepTime = 1000 - elapsed_time; end end function CheckManualOverrideItem( currentItem ) --ExtraDebug("Manual override check for: [" .. currentItem.id .. "]" .. currentItem.name); --fibaro:debug(currentItem.currentValue) --fibaro:debug(currentItem.OffMode) if (currentItem.currentValue == 0 and currentItem.OffMode ~= "ByScene" ) then ExtraDebug( "Manual override for light: [" .. currentItem.id .. "]" .. currentItem.name .. " active" ); return "ManualOverride"; elseif (currentItem.currentValue ~= 0 and currentItem.OffMode == "ManualOverride" ) then ExtraDebug( "Manual override for light: [" .. currentItem.id .. "]" .. currentItem.name .. " cancelled" ); return "NoOverride"; end return currentItem.OffMode; --returning current mode; end function RunManualOverrideMode( currentLightArray ) OverrideForAll = CheckIfAllInOverrideMode(currentLightArray); if ( OverrideForAll ) then ExtraDebug("-----------------Override Mode---------------"); OverrideTimer = os.time(); while ( OverrideForAll and (OverrideTimer + OverrideFor ) - os.time() > 0 ) do ExtraDebug("Still in override for: " .. (OverrideTimer + OverrideFor ) - os.time() .. " seconds" ); fibaro:sleep(1000); UpdateLightValues(currentLightArray); OverrideForAll = CheckIfAllInOverrideMode(currentLightArray); motion = GetCurrentMotionStatus(); if ( motion ~= 0 ) then OverrideTimer = os.time(); end end else return false; end -- if ( (OverrideTimer + OverrideFor ) - os.time() <= 0 ) then --time has end. So not continue to run lights loop -- return false; -- end if (OverrideForAll) then return false; --run lights else return true; end end function CheckIfAllInOverrideMode(currentLightArray) OverrideForAll = 0; for i = 1,#currentLightArray do if ( CheckManualOverrideItem(currentLightArray[i]) == "ManualOverride" ) then OverrideForAll = OverrideForAll +1; else return false; end end if ( OverrideForAll ~= 0 and OverrideForAll == #currentLightArray ) then return true; end return false; end function RunTimer() if ( keepLightsOn and not timerRunning ) then ExtraDebug("Starting timer, not yet running"); timerRunning = true; KeepLightsOnTimer(); else ExtraDebug("Timer already running, returning"); end end function TurnOffLights() local timeOfDayArray = GetTimeOfDayLightArray(); SetLightValues(timeOfDayArray); UpdateLightValues(timeOfDayArray); CallLightArray(timeOfDayArray, "off" ); return; end ----------------------Turn lights on functions------------------------ function CallLightArray( lightArray, turnOnOrOff ) if (#lightArray == 0 ) then if (CurrentState.sleepState == sleepStateMapping.Sleeping) then noLightsSetText = "lightsSleeping"; else noLightsSetText = CurrentState.timeOfDay; end StandardDebug( "No lights set for " .. noLightsSetText ); return; end if not ( CheckIfTable(lightArray, "lights" .. CurrentState.timeOfDay ) ) then return end for i = 1,#lightArray do if not ( CheckIfTable(lightArray[i], "lights" .. CurrentState.timeOfDay ) ) then break end lightItem = lightArray[i]; if (turnOnOrOff == "on" ) then turnLightOn(lightItem); if (lightItem.onTime ~= nil) then keepLightsOn = true; end else fibaro:call(lightItem.id, "turnOff"); --Always turn off, if HC2 light status is not actual. if ( lightItem.currentValue ~= 0) then keepLightsOn = false; StandardDebug("Switch off light: [" .. lightItem.id .. "]'" .. lightItem.name .."'"); end end end StandardDebug( "Lights turned: " .. turnOnOrOff .. " for " .. CurrentState.timeOfDay ); end function turnLightOn( lightItem ) if (lightItem.lightType == "com.fibaro.multilevelSwitch" ) then fibaro:call(lightItem.id, "setValue", tostring(lightItem.setValue)); StandardDebug( "Set: [" .. lightItem.id .. "]'" .. lightItem.name .. "' to Value: " .. lightItem.setValue ); elseif ( lightItem.lightType == "com.fibaro.RGBW" )then StandardDebug( "Turn: [" .. lightItem.id .. "]'" .. lightItem.name .. "' On"); if ( lightItem.setValue.brg~= nil ) then fibaro:call(lightItem.id, "setBrightness", tostring(lightItem.setValue.brg)); else local clrvalues =lightItem.setValue; fibaro:call(lightItem.id, "setColor", clrvalues.R, clrvalues.G, clrvalues.B, clrvalues.W) end elseif (lightItem.lightType == "com.fibaro.binarySwitch") then fibaro:call(lightItem.id, "turnOn"); StandardDebug( "Turn: [" .. lightItem.id .. "]'" .. lightItem.name .. "' On"); end end function CheckPreviousLights( NewLightArray ) if ( previousLights ~= nil ) then for i = 1,#previousLights do local lightItem = previousLights[i]; for i = 1,#NewLightArray do local lightItem1 = NewLightArray[i]; inarray = false; if ( lightItem.id == lightItem1.id ) then inarray= true; break end end if not ( inarray ) then fibaro:call(lightItem.id, "turnOff"); end end end previousLights = NewLightArray; end function LightperDayPart( minLux, lightArray ) local newLuxValue = CurrentState.lux; if ( extraLightTriggerChecks() ) then if ( newLuxValue > minLux ) then StandardDebug( "Sensor lux: " .. newLuxValue .. " higher then minValue: " .. minLux .. " : no action"); else StandardDebug("Sensor lux: " .. newLuxValue .. " is lower then minValue: " .. minLux); SetLightValues(lightArray); CallLightArray( lightArray, "on" ); CheckPreviousLights( lightArray ); end else ExtraDebug("ExtraLightTriggerChecks failed, so no lights"); end end function SceneTriggered() if ( CurrentState.homeStatus ~= presentStateMapping.Home ) then ExtraDebug("Presentstate = not at home, so no lights"); elseif ( CurrentState.sleepState == sleepStateMapping.Sleeping ) then LightperDayPart( 65535, lightsSleeping ); elseif ( CurrentState.timeOfDay == timeOfDayMapping.Morning ) then extraMorningFunc(); LightperDayPart( minLuxMorning, lightsMorning ); elseif ( CurrentState.timeOfDay == timeOfDayMapping.Day ) then extraDayFunc(); LightperDayPart( minLuxDay, lightsDay ); elseif ( CurrentState.timeOfDay == timeOfDayMapping.Evening ) then extraEveningFunc(); LightperDayPart( minLuxEvening, lightsEvening ); elseif ( CurrentState.timeOfDay == timeOfDayMapping.Night ) then extraNightFunc(); LightperDayPart( minLuxNight, lightsNight ); else ErrorDebug( "No lights: " .. CurrentState.timeOfDay ); end if (keepLightsOn == true) then RunTimer(); end end function SceneTriggeredByLights( st ) if (st == "off") then ExtraDebug( "light turned off, sleep 4 sec" ); fibaro:sleep(4000); elseif (st == "on") then ExtraDebug( "light turned on, activating timer" ); fibaro:sleep(4000); --TODO: add light to current array. --keepLightsOn = true; --RunTimer(); end end ------------------------STATUS functions------------------------------ function GetTimeOfDay() return LookupGlobal( timeOfDay, "TimeOfDay", "Day"); end function GetSleepState() return LookupGlobal( sleepState, "sleepState", "Awake"); end function GetPresentState() return LookupGlobal( presentState, "presentState", "Home"); end function LookupGlobal( name, stateName, default ) local ps = fibaro:getGlobalValue( name ); if ( (ps ~= "") and (ps ~= nil ) ) then ExtraDebug("returned " .. stateName .. ": " .. ps ); return ps; else ErrorDebug( stateName .. " variable not found"); return default; end end function lightsStatus( id ) --check if lights are already on. allLights = {lightsSleeping, lightsMorning, lightsDay, lightsEvening, lightsNight }; for i = 1,#allLights do for iL = 1, #allLights[i] do local lightItem = allLights[i][iL]; if ( lightItem.id == tonumber(id) ) then if ( lightItem.currentValue == 0 ) then return "off"; else return "on"; end end end end ErrorDebug("Light status unknown"); return "Unknown"; end function GetTimeOfDayLightArray() if ( CurrentState.sleepState == sleepStateMapping.Sleeping ) then return lightsSleeping; elseif ( CurrentState.timeOfDay == timeOfDayMapping.Morning ) then return lightsMorning; elseif ( CurrentState.timeOfDay == timeOfDayMapping.Day ) then return lightsDay; elseif ( CurrentState.timeOfDay == timeOfDayMapping.Evening ) then return lightsEvening; elseif ( CurrentState.timeOfDay == timeOfDayMapping.Night ) then return lightsNight; end end function GetCurrentMotionStatus() local sensorbreached = 0; if (CheckIfTable(motionSensorID, "motionSensorID") ) then for i = 1,#motionSensorID do if ( tonumber(fibaro:getValue(motionSensorID[i], "value")) > 0 ) then sensorbreached = 1; end end else --if not a table, just return the value of the containing ID sensorbreached = tonumber(fibaro:getValue(motionSensorID, "value")) end return sensorbreached; end function GetAverageLuxValue() local luxAverage = 0; if (CheckIfTable(LuxSensorID, "LuxSensorID") ) then if (#LuxSensorID == 1) then return tonumber(fibaro:getValue(LuxSensorID[1], "value")); end for i = 1,#LuxSensorID do luxAverage = luxAverage + tonumber(fibaro:getValue(LuxSensorID[i], "value")); end luxAverage = roundit( (luxAverage / #LuxSensorID), 0 ); else --if not a table, just return the value of the containing ID luxAverage = tonumber(fibaro:getValue(LuxSensorID, "value")); end return luxAverage; end function UpdateLightValues( currentArray ) for i = 1,#currentArray do item = currentArray[i]; newValue = fibaro:getValue(item.id, "value"); item.currentValue = tonumber(newValue) ~= nil and tonumber(newValue) or ( newValue == "true" and 1 or 0 ); if ( item.lightType == "com.fibaro.RGBW" )then color = fibaro:getValue(item.id, "color"); c = {R="0", G="0", B="0", W="0", brg="0" } c.R, c.G, c.B, c.W = color:match("([^,]+),([^,]+),([^,]+),([^,]+)"); c.brg = fibaro:getValue(item.id, "brightness"); item.currentValue = c; end end end function SetLightValues(currentArray) for i = 1,#currentArray do item = currentArray[i]; item.name = tostring(fibaro:getName(item.id)); item.OffMode = "NoOverride"; if (item.name == nil) then item.name = "Unknown"; end item.lightType = GetDeviceType( item.id ); end end function GetDeviceType(itemId) deviceType = fibaro:getType(item.id); if ( idIsInList(deviceType, RGBWDeviceType) ) then deviceType ="com.fibaro.RGBW"; elseif ( idIsInList(deviceType, BinaryDeviceType) ) then deviceType = "com.fibaro.binarySwitch"; elseif ( idIsInList(deviceType, DimmerDeviceType ) ) then deviceType = "com.fibaro.multilevelSwitch"; --elseif( ) then --deviceType = "Philips.Hue"; end return deviceType; end --------------------Helper functions-------------------------------- function CheckLightToBeTurnedOnAgain(lightItem) if not (lightItem.OffMode=="ByScene") then return; end if (lightItem.lightType == "com.fibaro.multilevelSwitch" ) then if (lightItem.currentValue) < tonumber(lightItem.setValue) then return true; end elseif( lightItem.lightType == "com.fibaro.RGBW" )then c = lightItem.currentValue; if (c.R == "0" and c.G == "0" and c.B == "0" and c.W == "0" ) then return true; end elseif (lightItem.lightType == "com.fibaro.binarySwitch") then if (lightItem.setValue == "turnOn" and lightItem.currentValue == 0 ) then return true; end end return false; end function CheckIfTable( array, arrayname ) local tableCheck = tostring( type( array ) ); if ( tableCheck ~= "table" ) then ErrorDebug("Missing brackets for variable: '" .. arrayname .. "', please place extra brackts: { } around: " .. array .. "."); return false; end return true; end function roundit(num, idp) local mult = 10^(idp or 0) return math.floor(num * mult + 0.5) / mult end function idIsInList( startSourceId, sensorList ) for i = 1,#sensorList do if ( startSourceId == sensorList[i] ) then return true; end end return false; end --------------------Debugging Functions----------------------------- function StandardDebug( debugMessage ) if ( showStandardDebugInfo ) then Debug( "white", debugMessage); end end function ExtraDebug( debugMessage ) if ( showExtraDebugInfo ) then Debug( "orange", debugMessage); end end function ErrorDebug( debugMessage ) Debug( "red", "Error: " .. debugMessage); Debug( "red", ""); end function TestDebug(debugMessage ) Debug( "blue", "Testing: " .. debugMessage ); end ----------------------START OF THE SCENE---------------------------- SetCurrentStatus(); StandardDebug("Home status: " .. CurrentState.homeStatus ); StandardDebug("Motion status: " .. ( CurrentState.motionState == 0 and "No movement" or "movement")); if (startSource["type"] == "property") then startSourceID = tonumber(startSource['deviceID']); triggerDebug = "Triggered by: " .. startSourceID; if ( idIsInList( startSourceID, motionSensorID ) ) then StandardDebug( triggerDebug .. " Motion sensor" ); if ( CurrentState.motionState > 0 ) then SceneTriggered(); end elseif ( idIsInList( startSourceID, LuxSensorID ) ) then StandardDebug( triggerDebug .. " Lux sensor" ); ExtraDebug( "Lux value changed to: " .. CurrentState.lux ); if ( CurrentState.motionState > 0 ) then SceneTriggered(); end else StandardDebug( triggerDebug .. " Light switch" ); st = lightsStatus( startSourceID ); if (st == "Unknown") then ErrorDebug( "Unknown light trigger" ); else SceneTriggeredByLights( st ); end -- Maybe we can change the light preset to make it more intelligent. -- Maybe we can change the Lux preset to make it more intelligent. end elseif ( startSource["type"] == "global" ) then StandardDebug( "Triggered by: " .. "global variable" ); -- If home status away, we trigger so the current array will be turned off. If motion, turn them on. if (CurrentState.homeStatus ~= presentStateMapping.Home) then TurnOffLights(); elseif (CurrentState.motionState > 0 ) then SceneTriggered(); end else StandardDebug( "Triggered by: " .. startSource["type"] .. " , Not checking the motion state." ); --Just run the Light Code, not checking for motion. Probably triggered manually. if ( startSource["type"] == "other" ) then SceneTriggered(); end end Debug( "green", "© Smart Lights V" .. version .. " | by Control Living, Finished" ); Debug( "green", "-------------------------------------------------------" ); --fibaro:abort(); --otherwise scene will stay alive to long. --UPDATE TILL HERE si quelqu'un a une idée ? merci de votre aide
- 171 réponses
- Smart Lights
- motion sensor
bonjour, merci pour la piste :-) en fait effectivement j'utilise un plugin perso pour gérer des switch knx via fhem et donc, pour que ça marche il faut rajouter dans la ligne 154 BinaryDeviceType = { "com.fibaro.binarySwitch","com.fibaro.FGWP101", "turnOn" } le type du plugin, pour moi ça donne ceci BinaryDeviceType = { "com.fibaro.binarySwitch","com.fibaro.FGWP101", "com.fibaro.developer.angelz.SwitchLumiereFhem", "turnOn" } et hop ça marche :-) maintenant que ca s'est réglé :-) est-il possible de faire en sorte que la détection se fasse sur 2 sec au lieu de faire ça a chaque détection ? merci de l'aide :-)
- 171 réponses
- Smart Lights
- motion sensor
voici la fin d'une "séquence" et le début d'une autre: [DEBUG] 19:49:52: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:49:52: Still in override for: 19 seconds [DEBUG] 19:49:53: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:49:53: Still in override for: 18 seconds [DEBUG] 19:49:54: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:49:54: Still in override for: 17 seconds [DEBUG] 19:49:55: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:49:55: Still in override for: 16 seconds [DEBUG] 19:49:56: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:49:56: Still in override for: 15 seconds [DEBUG] 19:49:57: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:49:57: Still in override for: 14 seconds [DEBUG] 19:49:58: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:49:58: Still in override for: 13 seconds [DEBUG] 19:49:59: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:49:59: Still in override for: 12 seconds [DEBUG] 19:50:00: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:50:00: Still in override for: 11 seconds [DEBUG] 19:50:01: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:50:01: Still in override for: 10 seconds [DEBUG] 19:50:02: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:50:02: Still in override for: 9 seconds [DEBUG] 19:50:03: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:50:03: Still in override for: 8 seconds [DEBUG] 19:50:04: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:50:04: Still in override for: 7 seconds [DEBUG] 19:50:05: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:50:05: Still in override for: 6 seconds [DEBUG] 19:50:06: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:50:06: Still in override for: 5 seconds [DEBUG] 19:50:07: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:50:07: Still in override for: 4 seconds [DEBUG] 19:50:08: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:50:08: Still in override for: 3 seconds [DEBUG] 19:50:09: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:50:09: Still in override for: 2 seconds [DEBUG] 19:50:10: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:50:10: Still in override for: 1 seconds [DEBUG] 19:50:11: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:50:11: © Smart Lights V1.6.7 | by Control Living, Finished [DEBUG] 19:50:11: ------------------------------------------------------- [DEBUG] 19:56:23: Updating current variable statuses [DEBUG] 19:56:23: returned presentState: Home [DEBUG] 19:56:23: returned TimeOfDay: Day [DEBUG] 19:56:23: returned sleepState: Awake [DEBUG] 19:56:23: Home status: Home [DEBUG] 19:56:23: Motion status: movement [DEBUG] 19:56:23: Triggered by: 42 Motion sensor [DEBUG] 19:56:23: Extra day function called [DEBUG] 19:56:23: Sensor lux: 500 is lower then minValue: 2500 [DEBUG] 19:56:23: Lights turned: on for Day [DEBUG] 19:56:23: Starting timer, not yet running [DEBUG] 19:56:23: --------------- Timer running --------------- [DEBUG] 19:56:23: starting with while loop, to keep lights on [DEBUG] 19:56:23: Saving current variable statuses [DEBUG] 19:56:23: --------------- next timer run --------------- [DEBUG] 19:56:24: Updating current variable statuses [DEBUG] 19:56:24: returned presentState: Home [DEBUG] 19:56:24: returned TimeOfDay: Day [DEBUG] 19:56:24: returned sleepState: Awake [DEBUG] 19:56:24: Status change check [DEBUG] 19:56:24: Saving current variable statuses [DEBUG] 19:56:24: Resetting time [DEBUG] 19:56:24: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:56:24: Manual override for light: [73]Spot Hall Entrée active, not turning on [DEBUG] 19:56:24: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:56:24: -----------------Override Mode--------------- [DEBUG] 19:56:24: Still in override for: 90 seconds [DEBUG] 19:56:25: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:56:25: Still in override for: 90 seconds [DEBUG] 19:56:26: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:56:26: Still in override for: 90 seconds [DEBUG] 19:56:27: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:56:27: Still in override for: 90 seconds [DEBUG] 19:56:28: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:56:28: Still in override for: 90 seconds [DEBUG] 19:56:29: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:56:29: Still in override for: 90 seconds [DEBUG] 19:56:30: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:56:30: Still in override for: 90 seconds [DEBUG] 19:56:31: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:56:31: Still in override for: 90 seconds [DEBUG] 19:56:32: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:56:32: Still in override for: 90 seconds [DEBUG] 19:56:33: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:56:33: Still in override for: 90 seconds [DEBUG] 19:56:34: Abort, Scene count = 2 [DEBUG] 19:56:34: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:56:34: Still in override for: 89 seconds [DEBUG] 19:56:35: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:56:35: Still in override for: 88 seconds [DEBUG] 19:56:36: Abort, Scene count = 2 [DEBUG] 19:56:36: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 19:56:36: Still in override for: 90 seconds
- 171 réponses
- Smart Lights
- motion sensor
voila la variable sleepState enlever pour les Maj/min j'ai vérifier tout est correct voici le log [DEBUG] 00:17:49: Updating current variable statuses [DEBUG] 00:17:49: returned presentState: Home [DEBUG] 00:17:49: returned TimeOfDay: Day [DEBUG] 00:17:49: returned sleepState: Awake [DEBUG] 00:17:49: Home status: Home [DEBUG] 00:17:49: Motion status: movement [DEBUG] 00:17:49: Triggered by: 42 Motion sensor [DEBUG] 00:17:49: Extra day function called [DEBUG] 00:17:49: Sensor lux: 0 is lower then minValue: 2500 [DEBUG] 00:17:49: Lights turned: on for Day [DEBUG] 00:17:49: Starting timer, not yet running [DEBUG] 00:17:49: --------------- Timer running --------------- [DEBUG] 00:17:49: starting with while loop, to keep lights on [DEBUG] 00:17:49: Saving current variable statuses [DEBUG] 00:17:49: --------------- next timer run --------------- [DEBUG] 00:17:50: Updating current variable statuses [DEBUG] 00:17:50: returned presentState: Home [DEBUG] 00:17:50: returned TimeOfDay: Day [DEBUG] 00:17:50: returned sleepState: Awake [DEBUG] 00:17:50: Status change check [DEBUG] 00:17:50: Saving current variable statuses [DEBUG] 00:17:50: Resetting time [DEBUG] 00:17:50: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:17:50: Manual override for light: [73]Spot Hall Entrée active, not turning on [DEBUG] 00:17:50: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:17:50: -----------------Override Mode--------------- [DEBUG] 00:17:50: Still in override for: 90 seconds [DEBUG] 00:17:51: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:17:51: Still in override for: 90 seconds [DEBUG] 00:17:52: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:17:52: Still in override for: 90 seconds [DEBUG] 00:17:53: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:17:53: Still in override for: 90 seconds [DEBUG] 00:17:54: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:17:54: Still in override for: 90 seconds [DEBUG] 00:17:55: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:17:55: Still in override for: 90 seconds [DEBUG] 00:17:56: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:17:56: Still in override for: 90 seconds [DEBUG] 00:17:57: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:17:57: Still in override for: 90 seconds [DEBUG] 00:17:58: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:17:58: Still in override for: 90 seconds [DEBUG] 00:17:59: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:17:59: Still in override for: 90 seconds [DEBUG] 00:18:00: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:00: Still in override for: 90 seconds [DEBUG] 00:18:01: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:01: Still in override for: 89 seconds [DEBUG] 00:18:01: Abort, Scene count = 2 [DEBUG] 00:18:02: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:02: Still in override for: 88 seconds [DEBUG] 00:18:03: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:03: Still in override for: 87 seconds [DEBUG] 00:18:04: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:04: Still in override for: 86 seconds [DEBUG] 00:18:05: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:05: Still in override for: 85 seconds [DEBUG] 00:18:06: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:06: Still in override for: 84 seconds [DEBUG] 00:18:07: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:07: Still in override for: 83 seconds [DEBUG] 00:18:08: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:08: Still in override for: 82 seconds [DEBUG] 00:18:09: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:09: Still in override for: 81 seconds [DEBUG] 00:18:10: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:10: Still in override for: 80 seconds [DEBUG] 00:18:11: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:11: Still in override for: 79 seconds [DEBUG] 00:18:12: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:12: Still in override for: 78 seconds [DEBUG] 00:18:13: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:13: Still in override for: 77 seconds [DEBUG] 00:18:14: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:14: Still in override for: 76 seconds [DEBUG] 00:18:15: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:15: Still in override for: 75 seconds [DEBUG] 00:18:16: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:16: Still in override for: 74 seconds [DEBUG] 00:18:17: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:17: Still in override for: 73 seconds [DEBUG] 00:18:18: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:18: Still in override for: 72 seconds [DEBUG] 00:18:19: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:19: Still in override for: 71 seconds [DEBUG] 00:18:20: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:20: Still in override for: 70 seconds [DEBUG] 00:18:21: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:21: Still in override for: 69 seconds [DEBUG] 00:18:22: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:22: Still in override for: 68 seconds [DEBUG] 00:18:23: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:23: Still in override for: 67 seconds [DEBUG] 00:18:24: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:24: Still in override for: 66 seconds [DEBUG] 00:18:25: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:25: Still in override for: 65 seconds [DEBUG] 00:18:26: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:26: Still in override for: 64 seconds [DEBUG] 00:18:27: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:27: Still in override for: 63 seconds [DEBUG] 00:18:28: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:28: Still in override for: 62 seconds [DEBUG] 00:18:29: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:29: Still in override for: 61 seconds [DEBUG] 00:18:30: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:30: Still in override for: 60 seconds [DEBUG] 00:18:31: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:31: Still in override for: 59 seconds [DEBUG] 00:18:32: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:32: Still in override for: 58 seconds [DEBUG] 00:18:33: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:33: Still in override for: 57 seconds [DEBUG] 00:18:34: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:34: Still in override for: 56 seconds [DEBUG] 00:18:35: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:35: Still in override for: 55 seconds [DEBUG] 00:18:36: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:36: Still in override for: 54 seconds [DEBUG] 00:18:37: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:37: Still in override for: 53 seconds [DEBUG] 00:18:38: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:38: Still in override for: 52 seconds [DEBUG] 00:18:39: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:39: Still in override for: 51 seconds [DEBUG] 00:18:40: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:40: Still in override for: 50 seconds [DEBUG] 00:18:41: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:41: Still in override for: 49 seconds [DEBUG] 00:18:42: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:42: Still in override for: 48 seconds [DEBUG] 00:18:43: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:43: Still in override for: 47 seconds [DEBUG] 00:18:44: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:44: Still in override for: 46 seconds [DEBUG] 00:18:45: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:45: Still in override for: 45 seconds [DEBUG] 00:18:46: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:46: Still in override for: 44 seconds [DEBUG] 00:18:47: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:47: Still in override for: 43 seconds [DEBUG] 00:18:48: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:48: Still in override for: 42 seconds [DEBUG] 00:18:49: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:49: Still in override for: 41 seconds [DEBUG] 00:18:50: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:50: Still in override for: 40 seconds [DEBUG] 00:18:51: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:51: Still in override for: 39 seconds [DEBUG] 00:18:52: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:52: Still in override for: 38 seconds [DEBUG] 00:18:53: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:53: Still in override for: 37 seconds [DEBUG] 00:18:54: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:54: Still in override for: 36 seconds [DEBUG] 00:18:55: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:55: Still in override for: 35 seconds [DEBUG] 00:18:56: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:56: Still in override for: 34 seconds [DEBUG] 00:18:57: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:57: Still in override for: 33 seconds [DEBUG] 00:18:58: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:58: Still in override for: 32 seconds [DEBUG] 00:18:59: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:18:59: Still in override for: 31 seconds [DEBUG] 00:19:00: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:00: Still in override for: 30 seconds [DEBUG] 00:19:01: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:01: Still in override for: 29 seconds [DEBUG] 00:19:02: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:02: Still in override for: 28 seconds [DEBUG] 00:19:03: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:03: Still in override for: 27 seconds [DEBUG] 00:19:04: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:04: Still in override for: 26 seconds [DEBUG] 00:19:05: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:05: Still in override for: 25 seconds [DEBUG] 00:19:06: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:06: Still in override for: 24 seconds [DEBUG] 00:19:07: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:07: Still in override for: 23 seconds [DEBUG] 00:19:08: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:08: Still in override for: 22 seconds [DEBUG] 00:19:09: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:09: Still in override for: 21 seconds [DEBUG] 00:19:10: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:10: Still in override for: 20 seconds [DEBUG] 00:19:11: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:11: Still in override for: 19 seconds [DEBUG] 00:19:12: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:12: Still in override for: 18 seconds [DEBUG] 00:19:13: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:13: Still in override for: 17 seconds [DEBUG] 00:19:14: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:14: Still in override for: 16 seconds [DEBUG] 00:19:15: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:15: Still in override for: 15 seconds [DEBUG] 00:19:16: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:16: Still in override for: 14 seconds [DEBUG] 00:19:17: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:17: Still in override for: 13 seconds [DEBUG] 00:19:18: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:18: Still in override for: 12 seconds [DEBUG] 00:19:19: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:19: Still in override for: 11 seconds [DEBUG] 00:19:20: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:20: Still in override for: 10 seconds [DEBUG] 00:19:21: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:21: Still in override for: 9 seconds [DEBUG] 00:19:22: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:22: Still in override for: 8 seconds [DEBUG] 00:19:23: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:23: Still in override for: 7 seconds [DEBUG] 00:19:24: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:24: Still in override for: 6 seconds [DEBUG] 00:19:25: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:25: Still in override for: 5 seconds [DEBUG] 00:19:26: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:26: Still in override for: 4 seconds [DEBUG] 00:19:27: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:27: Still in override for: 3 seconds [DEBUG] 00:19:28: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:28: Still in override for: 2 seconds [DEBUG] 00:19:29: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:29: Still in override for: 1 seconds [DEBUG] 00:19:30: Manual override for light: [73]Spot Hall Entrée active [DEBUG] 00:19:30: © Smart Lights V1.6.7 | by Control Living, Finished [DEBUG] 00:19:30: -------------------------------------------------------
- 171 réponses
- Smart Lights
- motion sensor
j'ai enlever la ligne vide mais toujours pas voici le script total :-) --[[ %% properties 42 value 53 value %% globals TimeOfDay PresentState sleepState --]] --[[ Change - XXX value - above. One for motion sensor, one for Light sensor. TimeOfDay global variable and lux make sure that the scene will be triggered when you are already in the room and something changes. Set your settings below, lights and add extra functions Feel free to suggest changes or contact when having problems. It is not allowed to sell or distribute this software and earlier versions without the approval of Control Living © 2014 - 2015 Smart lights by Control Living Version 1.6.7 --]] -------------------------------------------------------------------- -----------------------YOUR LIGHT SETTINGS-------------------------- motionSensorID = {42}; -- change id for your motion sensor. LuxSensorID = {53}; -- change id for your light sensor. --Enter the name of your Global variable. WITHOUT IT, THE SCENE DOES NOT WORK. Capital sensitive! sleepState = "SleepState"; --Sleep globalstate variable. timeOfDay = "TimeOfDay"; --Time of Day Global variable. presentState = "PresentState"; --Present state Global variable. --Enter the values of your global variables stated above. If not using, copy the name in front of the "YourValueName" sleepStateMapping = {Sleeping="Sleeping", Awake="Awake"}; timeOfDayMapping = {Morning="Morning", Day="Day", Evening="Evening", Night="Night"}; presentStateMapping = {Home="Home", Away="Away", Holiday="Holiday"}; -- Set the lux value for which the lights have to be turned on. -- If you don't want to use the MinLux then just set it to: 65535 minLuxMorning = 2500; minLuxDay = 2500; minLuxEvening = 2500; minLuxNight = 2500; --If the current lux value is above the maxlux, the lights will turn off after their set onTime. maxLuxMorning = 6000; maxLuxDay = 6000; --[[ Now the most important part: Here you can enter what light, for how long and at what value has to be turned on. Leave empty brackets for no lights. To set the light value without timer use 2 parameters: {id=LightID, setValue="VALUE"} To set the light value with timer use 3 parameters: {id=LightID, setValue="VALUE", onTime=timeInSeconds } To set the light value for RGBW: use the above, where setValue is: setValue={R="255",G="255",B="255",W="255"} -- RGBW set: {id=LightID, setValue={R="255",G="255",B="255",W="255"}, onTime=timeInSeconds } --]] --lightsSleeping = {}; --lights that are triggered when Sleepstate is sleeping. --lightsMorning = {{id=471, setValue="99", onTime=300},{id=491, setValue="99", onTime=300},{id=902, setValue="turnOn", onTime=360}}; --lightsDay = {{id=471, setValue="80", onTime=90},{id=491, setValue="80", onTime=90}}; --lightsEvening = {{id=471, setValue="60", onTime=300},{id=491, setValue="60", onTime=300},{id=902, setValue="turnOn", onTime=300}}; --lightsNight = {{id=471, setValue="45", onTime=60}, {id=491, setValue="45", onTime=60}}; lightsSleeping = {}; --lights that are triggered when Sleepstate is sleeping. lightsMorning = {{id=73, setValue="turnOn", onTime=360}}; lightsDay = {{id=73, setValue="turnOn", onTime=360}}; lightsEvening = {{id=73, setValue="turnOn", onTime=360}}; lightsNight = {{id=73, setValue="turnOn", onTime=360}}; --Manual Override, the time that lights will not be turned ON again after manually turning them off. OverrideFor = 90; dimmDownTime = 10; -------------------------------------------------------------------- -------------------------EXTRA FEATURES----------------------------- extraMorningFunc = function() -- Add your extra code here. If you want some checks or maybe run a virtual device button. --This code is always triggered if there is motion. -- movieLights = {{180, "10"},{181, "10"} }; --if (xbmc == "playing" ) then CallLightArray(movieLights); ExtraDebug("Extra morning function called"); end extraDayFunc = function() -- Add your extra code here. If you want some checks or maybe run a virtual device button. --This code is always triggered if there is motion. ExtraDebug("Extra day function called"); end extraEveningFunc = function() -- Add your extra code here. If you want some checks or maybe run a virtual device button. --This code is always triggered if there is motion. ExtraDebug("Extra evening function called"); end extraNightFunc = function() -- Add your extra code here. If you want some checks or maybe run a virtual device button. --This code is always triggered if there is motion. ExtraDebug("Extra night function called"); end extraLightTriggerChecks = function() --add extra checks here. and return the total true or false value. --if returning false the lights will not be triggered. -- for instance: return ( (pcTurnedOff == true ) and (xbmc ~= "Empty") ); -- return true to enable lights to turn on return true; end extraOffChecks = function() --return true to keep lights on. return false; end -------------------------------------------------------------------- ----------------------ADVANCES SETTINGS----------------------------- local showStandardDebugInfo = true; -- Debug shown in white local showExtraDebugInfo = false; -- Debug shown in orange -------------------------------------------------------------------- -------------------------------------------------------------------- -- DO NOT CHANGE THE CODE BELOW -- -------------------------------------------------------------------- --UPDATE FROM HERE --private variables startSource = fibaro:getSourceTrigger(); keepLightsOn = false; timerRunning = false; previousLights = nil; version = "1.6.7"; SavedState = { homeStatus = "", sleepState = 0, timeOfDay = "", lux = 0, motion = 0, startTime = 0 } CurrentState = { homeStatus = "", sleepState = "", timeOfDay = "", lux = 0, motionState = 0, currentLightArray = {} } RGBWDeviceType = { "com.fibaro.RGBW", "com.fibaro.colorController", "com.fibaro.FGRGBW441M" } BinaryDeviceType = { "com.fibaro.binarySwitch","com.fibaro.FGWP101", "turnOn" } DimmerDeviceType = { "com.fibaro.multilevelSwitch" } OffModes = {None, ByScene, ManualOverride } function Debug( color, message ) fibaro:debug(string.format('<%s style="color:%s;">%s</%s>', "span", color, message, "span")); end --Making sure that only one instance of the scene is running. fibaro:sleep(50); --sleep to prevent all instances being killed. if (fibaro:countScenes() > 1) then if (showExtraDebugInfo) then Debug( "grey", "Abort, Scene count = " .. fibaro:countScenes()); end fibaro:abort(); end --------------------------EXECUTION---------------------------------- function SetCurrentStatus() ExtraDebug("Updating current variable statuses"); CurrentState.homeStatus = GetPresentState(); CurrentState.timeOfDay = GetTimeOfDay(); CurrentState.sleepState = GetSleepState(); CurrentState.lux = GetAverageLuxValue(); CurrentState.motionState = GetCurrentMotionStatus(); end function SaveCurrentStatus() ExtraDebug("Saving current variable statuses"); SavedState.homeStatus = CurrentState.homeStatus; SavedState.timeOfDay = CurrentState.timeOfDay; SavedState.sleepState = CurrentState.sleepState; SavedState.lux = CurrentState.lux; SavedState.motion = CurrentState.motionState; end function CheckStatusChanges() ExtraDebug("Status change check"); if (CurrentState.homeStatus ~= SavedState.homeStatus ) or (CurrentState.timeOfDay ~= SavedState.timeOfDay ) then if (CurrentState.homeStatus ~= presentStateMapping.Home ) then TurnOffLights(); else SceneTriggered(); --reset time. end; end SaveCurrentStatus(); -- if we still have a motion then reset timer. if ( (CurrentState.motionState ~= 0 or extraOffChecks() ) and not IsMaxLuxExceeded() ) then ExtraDebug( "Resetting time" ); SavedState.startTime = os.time(); else ExtraDebug("Timer is not reset."); end --any other case, we are not resetting the timer. end function IsMaxLuxExceeded() if (CurrentState.timeOfDay == timeOfDayMapping.Morning and CurrentState.lux > maxLuxMorning ) then ExtraDebug( "Current lux value: " .. CurrentState.lux .. " higher then max Lux Morning: " .. maxLuxMorning .. "."); return true; elseif (CurrentState.timeOfDay == timeOfDayMapping.Day and CurrentState.lux > maxLuxDay ) then ExtraDebug( "Current lux value: " .. CurrentState.lux .. " higher then max Lux Day: " .. maxLuxDay .. "."); return true; end return false; end function LightsOff( lightArray ) local stillLightsOn = 0; local currentTime = os.time(); for i = 1,#lightArray do if ( lightArray[i].onTime ~= nil) then lightItem = lightArray[i]; lightItem.OffMode = CheckManualOverrideItem( lightItem ); --local if ( lightItem.OffMode == "ManualOverride" ) then ExtraDebug("Manual override for light: [" .. lightItem.id .. "]" .. lightItem.name .. " active, not turning on"); goto continue; end --On till: local timeL = SavedState.startTime + (lightItem.onTime); local timeLeft = timeL - currentTime; if (timeLeft >= 0 ) then ExtraDebug("Time left for: [" .. lightItem.id .. "]" .. lightItem.name .. ": " .. timeLeft .. " seconds" ); end if ( timeLeft < dimmDownTime ) then if ( lightItem.OffMode ~= "ManualOverride" ) then lightItem.OffMode = "ByScene"; end if ( (timeLeft <= 0) and (lightItem.currentValue ~= 0) ) then fibaro:call(lightItem.id, "turnOff"); StandardDebug("Switch off light: [" .. lightItem.id .. "]'" .. lightItem.name .."'"); else if ( item.lightType == "com.fibaro.multilevelSwitch" ) then currentValueDiv = roundit(((lightItem.currentValue) / (dimmDownTime)), 0); currentValueNew = (lightItem.currentValue - currentValueDiv); if (currentValueNew <=0 ) then currentValueNew = 0; end fibaro:call(lightItem.id, "setValue", tostring(currentValueNew)); end stillLightsOn = stillLightsOn + 1; end elseif (CheckLightToBeTurnedOnAgain(lightItem)) then ExtraDebug("Turn light: " .. lightItem.id .. " back on"); turnLightOn(lightItem); lightItem.OffMode = ""; stillLightsOn = stillLightsOn + 1; else lightItem.OffMode = "NoOverride"; stillLightsOn = stillLightsOn + 1; end end ::continue:: end return stillLightsOn; end function KeepLightsOnTimer() ExtraDebug("--------------- Timer running ---------------"); ExtraDebug("starting with while loop, to keep lights on"); SavedState.startTime = os.time(); SaveCurrentStatus(); sleepTime = 1000; while ( keepLightsOn ) do ExtraDebug("--------------- next timer run ---------------"); fibaro:sleep(sleepTime); start_time = os.clock(); SetCurrentStatus(); currentLightArray = GetTimeOfDayLightArray(); UpdateLightValues(currentLightArray); CheckStatusChanges(); local stillLightsOn = 0; stillLightsOn = LightsOff( currentLightArray ); if (stillLightsOn == 0 ) then keepLightsOn = RunManualOverrideMode( currentLightArray ); end_time = 0; --if lights turned back on after override. else end_time = os.clock() end elapsed_time = (end_time - start_time) * 1000; sleepTime = 1000 - elapsed_time; end end function CheckManualOverrideItem( currentItem ) --ExtraDebug("Manual override check for: [" .. currentItem.id .. "]" .. currentItem.name); if (currentItem.currentValue == 0 and currentItem.OffMode ~= "ByScene" ) then ExtraDebug( "Manual override for light: [" .. currentItem.id .. "]" .. currentItem.name .. " active" ); return "ManualOverride"; elseif (currentItem.currentValue ~= 0 and currentItem.OffMode == "ManualOverride" ) then ExtraDebug( "Manual override for light: [" .. currentItem.id .. "]" .. currentItem.name .. " cancelled" ); return "NoOverride"; end return currentItem.OffMode; --returning current mode; end function RunManualOverrideMode( currentLightArray ) OverrideForAll = CheckIfAllInOverrideMode(currentLightArray); if ( OverrideForAll ) then ExtraDebug("-----------------Override Mode---------------"); OverrideTimer = os.time(); while ( OverrideForAll and (OverrideTimer + OverrideFor ) - os.time() > 0 ) do ExtraDebug("Still in override for: " .. (OverrideTimer + OverrideFor ) - os.time() .. " seconds" ); fibaro:sleep(1000); UpdateLightValues(currentLightArray); OverrideForAll = CheckIfAllInOverrideMode(currentLightArray); motion = GetCurrentMotionStatus(); if ( motion ~= 0 ) then OverrideTimer = os.time(); end end else return false; end -- if ( (OverrideTimer + OverrideFor ) - os.time() <= 0 ) then --time has end. So not continue to run lights loop -- return false; -- end if (OverrideForAll) then return false; --run lights else return true; end end function CheckIfAllInOverrideMode(currentLightArray) OverrideForAll = 0; for i = 1,#currentLightArray do if ( CheckManualOverrideItem(currentLightArray[i]) == "ManualOverride" ) then OverrideForAll = OverrideForAll +1; else return false; end end if ( OverrideForAll ~= 0 and OverrideForAll == #currentLightArray ) then return true; end return false; end function RunTimer() if ( keepLightsOn and not timerRunning ) then ExtraDebug("Starting timer, not yet running"); timerRunning = true; KeepLightsOnTimer(); else ExtraDebug("Timer already running, returning"); end end function TurnOffLights() local timeOfDayArray = GetTimeOfDayLightArray(); SetLightValues(timeOfDayArray); UpdateLightValues(timeOfDayArray); CallLightArray(timeOfDayArray, "off" ); return; end ----------------------Turn lights on functions------------------------ function CallLightArray( lightArray, turnOnOrOff ) if (#lightArray == 0 ) then if (CurrentState.sleepState == sleepStateMapping.Sleeping) then noLightsSetText = "lightsSleeping"; else noLightsSetText = CurrentState.timeOfDay; end StandardDebug( "No lights set for " .. noLightsSetText ); return; end if not ( CheckIfTable(lightArray, "lights" .. CurrentState.timeOfDay ) ) then return end for i = 1,#lightArray do if not ( CheckIfTable(lightArray[i], "lights" .. CurrentState.timeOfDay ) ) then break end lightItem = lightArray[i]; if (turnOnOrOff == "on" ) then turnLightOn(lightItem); if (lightItem.onTime ~= nil) then keepLightsOn = true; end else fibaro:call(lightItem.id, "turnOff"); --Always turn off, if HC2 light status is not actual. if ( lightItem.currentValue ~= 0) then keepLightsOn = false; StandardDebug("Switch off light: [" .. lightItem.id .. "]'" .. lightItem.name .."'"); end end end StandardDebug( "Lights turned: " .. turnOnOrOff .. " for " .. CurrentState.timeOfDay ); end function turnLightOn( lightItem ) if (lightItem.lightType == "com.fibaro.multilevelSwitch" ) then fibaro:call(lightItem.id, "setValue", tostring(lightItem.setValue)); StandardDebug( "Set: [" .. lightItem.id .. "]'" .. lightItem.name .. "' to Value: " .. lightItem.setValue ); elseif ( lightItem.lightType == "com.fibaro.RGBW" )then StandardDebug( "Turn: [" .. lightItem.id .. "]'" .. lightItem.name .. "' On"); if ( lightItem.setValue.brg~= nil ) then fibaro:call(lightItem.id, "setBrightness", tostring(lightItem.setValue.brg)); else local clrvalues =lightItem.setValue; fibaro:call(lightItem.id, "setColor", clrvalues.R, clrvalues.G, clrvalues.B, clrvalues.W) end elseif (lightItem.lightType == "com.fibaro.binarySwitch") then fibaro:call(lightItem.id, "turnOn"); StandardDebug( "Turn: [" .. lightItem.id .. "]'" .. lightItem.name .. "' On"); end end function CheckPreviousLights( NewLightArray ) if ( previousLights ~= nil ) then for i = 1,#previousLights do local lightItem = previousLights[i]; for i = 1,#NewLightArray do local lightItem1 = NewLightArray[i]; inarray = false; if ( lightItem.id == lightItem1.id ) then inarray= true; break end end if not ( inarray ) then fibaro:call(lightItem.id, "turnOff"); end end end previousLights = NewLightArray; end function LightperDayPart( minLux, lightArray ) local newLuxValue = CurrentState.lux; if ( extraLightTriggerChecks() ) then if ( newLuxValue > minLux ) then StandardDebug( "Sensor lux: " .. newLuxValue .. " higher then minValue: " .. minLux .. " : no action"); else StandardDebug("Sensor lux: " .. newLuxValue .. " is lower then minValue: " .. minLux); SetLightValues(lightArray); CallLightArray( lightArray, "on" ); CheckPreviousLights( lightArray ); end else ExtraDebug("ExtraLightTriggerChecks failed, so no lights"); end end function SceneTriggered() if ( CurrentState.homeStatus ~= presentStateMapping.Home ) then ExtraDebug("Presentstate = not at home, so no lights"); elseif ( CurrentState.sleepState == sleepStateMapping.Sleeping ) then LightperDayPart( 65535, lightsSleeping ); elseif ( CurrentState.timeOfDay == timeOfDayMapping.Morning ) then extraMorningFunc(); LightperDayPart( minLuxMorning, lightsMorning ); elseif ( CurrentState.timeOfDay == timeOfDayMapping.Day ) then extraDayFunc(); LightperDayPart( minLuxDay, lightsDay ); elseif ( CurrentState.timeOfDay == timeOfDayMapping.Evening ) then extraEveningFunc(); LightperDayPart( minLuxEvening, lightsEvening ); elseif ( CurrentState.timeOfDay == timeOfDayMapping.Night ) then extraNightFunc(); LightperDayPart( minLuxNight, lightsNight ); else ErrorDebug( "No lights: " .. CurrentState.timeOfDay ); end if (keepLightsOn == true) then RunTimer(); end end function SceneTriggeredByLights( st ) if (st == "off") then ExtraDebug( "light turned off, sleep 4 sec" ); fibaro:sleep(4000); elseif (st == "on") then ExtraDebug( "light turned on, activating timer" ); fibaro:sleep(4000); --TODO: add light to current array. --keepLightsOn = true; --RunTimer(); end end ------------------------STATUS functions------------------------------ function GetTimeOfDay() return LookupGlobal( timeOfDay, "TimeOfDay", "Day"); end function GetSleepState() return LookupGlobal( sleepState, "sleepState", "Awake"); end function GetPresentState() return LookupGlobal( presentState, "presentState", "Home"); end function LookupGlobal( name, stateName, default ) local ps = fibaro:getGlobalValue( name ); if ( (ps ~= "") and (ps ~= nil ) ) then ExtraDebug("returned " .. stateName .. ": " .. ps ); return ps; else ErrorDebug( stateName .. " variable not found"); return default; end end function lightsStatus( id ) --check if lights are already on. allLights = {lightsSleeping, lightsMorning, lightsDay, lightsEvening, lightsNight }; for i = 1,#allLights do for iL = 1, #allLights[i] do local lightItem = allLights[i][iL]; if ( lightItem.id == tonumber(id) ) then if ( lightItem.currentValue == 0 ) then return "off"; else return "on"; end end end end ErrorDebug("Light status unknown"); return "Unknown"; end function GetTimeOfDayLightArray() if ( CurrentState.sleepState == sleepStateMapping.Sleeping ) then return lightsSleeping; elseif ( CurrentState.timeOfDay == timeOfDayMapping.Morning ) then return lightsMorning; elseif ( CurrentState.timeOfDay == timeOfDayMapping.Day ) then return lightsDay; elseif ( CurrentState.timeOfDay == timeOfDayMapping.Evening ) then return lightsEvening; elseif ( CurrentState.timeOfDay == timeOfDayMapping.Night ) then return lightsNight; end end function GetCurrentMotionStatus() local sensorbreached = 0; if (CheckIfTable(motionSensorID, "motionSensorID") ) then for i = 1,#motionSensorID do if ( tonumber(fibaro:getValue(motionSensorID[i], "value")) > 0 ) then sensorbreached = 1; end end else --if not a table, just return the value of the containing ID sensorbreached = tonumber(fibaro:getValue(motionSensorID, "value")) end return sensorbreached; end function GetAverageLuxValue() local luxAverage = 0; if (CheckIfTable(LuxSensorID, "LuxSensorID") ) then if (#LuxSensorID == 1) then return tonumber(fibaro:getValue(LuxSensorID[1], "value")); end for i = 1,#LuxSensorID do luxAverage = luxAverage + tonumber(fibaro:getValue(LuxSensorID[i], "value")); end luxAverage = roundit( (luxAverage / #LuxSensorID), 0 ); else --if not a table, just return the value of the containing ID luxAverage = tonumber(fibaro:getValue(LuxSensorID, "value")); end return luxAverage; end function UpdateLightValues( currentArray ) for i = 1,#currentArray do item = currentArray[i]; newValue = fibaro:getValue(item.id, "value"); item.currentValue = tonumber(newValue) ~= nil and tonumber(newValue) or ( newValue == "true" and 1 or 0 ); if ( item.lightType == "com.fibaro.RGBW" )then color = fibaro:getValue(item.id, "color"); c = {R="0", G="0", B="0", W="0", brg="0" } c.R, c.G, c.B, c.W = color:match("([^,]+),([^,]+),([^,]+),([^,]+)"); c.brg = fibaro:getValue(item.id, "brightness"); item.currentValue = c; end end end function SetLightValues(currentArray) for i = 1,#currentArray do item = currentArray[i]; item.name = tostring(fibaro:getName(item.id)); item.OffMode = "NoOverride"; if (item.name == nil) then item.name = "Unknown"; end item.lightType = GetDeviceType( item.id ); end end function GetDeviceType(itemId) deviceType = fibaro:getType(item.id); if ( idIsInList(deviceType, RGBWDeviceType) ) then deviceType ="com.fibaro.RGBW"; elseif ( idIsInList(deviceType, BinaryDeviceType) ) then deviceType = "com.fibaro.binarySwitch"; elseif ( idIsInList(deviceType, DimmerDeviceType ) ) then deviceType = "com.fibaro.multilevelSwitch"; --elseif( ) then --deviceType = "Philips.Hue"; end return deviceType; end --------------------Helper functions-------------------------------- function CheckLightToBeTurnedOnAgain(lightItem) if not (lightItem.OffMode=="ByScene") then return; end if (lightItem.lightType == "com.fibaro.multilevelSwitch" ) then if (lightItem.currentValue) < tonumber(lightItem.setValue) then return true; end elseif( lightItem.lightType == "com.fibaro.RGBW" )then c = lightItem.currentValue; if (c.R == "0" and c.G == "0" and c.B == "0" and c.W == "0" ) then return true; end elseif (lightItem.lightType == "com.fibaro.binarySwitch") then if (lightItem.setValue == "turnOn" and lightItem.currentValue == 0 ) then return true; end end return false; end function CheckIfTable( array, arrayname ) local tableCheck = tostring( type( array ) ); if ( tableCheck ~= "table" ) then ErrorDebug("Missing brackets for variable: '" .. arrayname .. "', please place extra brackts: { } around: " .. array .. "."); return false; end return true; end function roundit(num, idp) local mult = 10^(idp or 0) return math.floor(num * mult + 0.5) / mult end function idIsInList( startSourceId, sensorList ) for i = 1,#sensorList do if ( startSourceId == sensorList[i] ) then return true; end end return false; end --------------------Debugging Functions----------------------------- function StandardDebug( debugMessage ) if ( showStandardDebugInfo ) then Debug( "white", debugMessage); end end function ExtraDebug( debugMessage ) if ( showExtraDebugInfo ) then Debug( "orange", debugMessage); end end function ErrorDebug( debugMessage ) Debug( "red", "Error: " .. debugMessage); Debug( "red", ""); end function TestDebug(debugMessage ) Debug( "blue", "Testing: " .. debugMessage ); end ----------------------START OF THE SCENE---------------------------- SetCurrentStatus(); StandardDebug("Home status: " .. CurrentState.homeStatus ); StandardDebug("Motion status: " .. ( CurrentState.motionState == 0 and "No movement" or "movement")); if (startSource["type"] == "property") then startSourceID = tonumber(startSource['deviceID']); triggerDebug = "Triggered by: " .. startSourceID; if ( idIsInList( startSourceID, motionSensorID ) ) then StandardDebug( triggerDebug .. " Motion sensor" ); if ( CurrentState.motionState > 0 ) then SceneTriggered(); end elseif ( idIsInList( startSourceID, LuxSensorID ) ) then StandardDebug( triggerDebug .. " Lux sensor" ); ExtraDebug( "Lux value changed to: " .. CurrentState.lux ); if ( CurrentState.motionState > 0 ) then SceneTriggered(); end else StandardDebug( triggerDebug .. " Light switch" ); st = lightsStatus( startSourceID ); if (st == "Unknown") then ErrorDebug( "Unknown light trigger" ); else SceneTriggeredByLights( st ); end -- Maybe we can change the light preset to make it more intelligent. -- Maybe we can change the Lux preset to make it more intelligent. end elseif ( startSource["type"] == "global" ) then StandardDebug( "Triggered by: " .. "global variable" ); -- If home status away, we trigger so the current array will be turned off. If motion, turn them on. if (CurrentState.homeStatus ~= presentStateMapping.Home) then TurnOffLights(); elseif (CurrentState.motionState > 0 ) then SceneTriggered(); end else StandardDebug( "Triggered by: " .. startSource["type"] .. " , Not checking the motion state." ); --Just run the Light Code, not checking for motion. Probably triggered manually. if ( startSource["type"] == "other" ) then SceneTriggered(); end end Debug( "green", "© Smart Lights V" .. version .. " | by Control Living, Finished" ); Debug( "green", "-------------------------------------------------------" ); --fibaro:abort(); --otherwise scene will stay alive to long. --UPDATE TILL HERE j’espère que cela pourra aider a décortiquer cette histoire :-)
- 171 réponses
- Smart Lights
- motion sensor
voici l'entete : --[[ %% properties 42 value 53 value %% globals TimeOfDay PresentState sleepState --]] 42 --> mouvement 53 --> lux -------------------------------------------------------------------- -----------------------YOUR LIGHT SETTINGS-------------------------- motionSensorID = {42}; -- change id for your motion sensor. LuxSensorID = {53}; -- change id for your light sensor. je ne vois vraiment pas pourquoi cela ne s'allume pas ...
- 171 réponses
- Smart Lights
- motion sensor
donc si je vous suis -- Set the lux value for which the lights have to be turned on. -- If you don't want to use the MinLux then just set it to: 65535 minLuxMorning = 2500; minLuxDay = 2500; minLuxEvening = 2500; minLuxNight = 2500; --If the current lux value is above the maxlux, the lights will turn off after their set onTime. maxLuxMorning = 6000; maxLuxDay = 6000; la les min sont a 2500 donc en dessous de 2500 cela s'allume pour le moment la sonde lux donne 500 donc on est bon ? etat des VG : SleepState = .Awake TimeOfDay = Day PresentState = Home commande pour l'allumage : lightsSleeping = {}; --lights that are triggered when Sleepstate is sleeping. lightsMorning = {{id=73, setValue="turnOn", onTime=360}}; lightsDay = {{id=73, setValue="turnOn", onTime=360}}; lightsEvening = {{id=73, setValue="turnOn", onTime=360}}; lightsNight = {{id=73, setValue="turnOn", onTime=360}}; si je ne me trompe pas tout a l'air correct non ?
- 171 réponses
- Smart Lights
- motion sensor
c'est juste une échelle de valeur différente toi 0 --> 20 par ex (0% = 0 et 100% = 20) moi 0 --> 5000 (0% = 0 et 100% = 5000) après c'est juste une autre échelle mais ça devrait marcher.... je ne comprends pas
- 171 réponses
- Smart Lights
- motion sensor
les sondes réagisse bien lumière éteinte 500lux (un peu sombre mais on vois un peu) lumière allumé 5196 lux je suis d'accord sur le fait que les valeur soit bizarre mais bon au lieu de me basé sur min 5 max 15, je me base sur min 500 max 2500 en prod ça ne devrait pas interférer avec le scripts
- 171 réponses
- Smart Lights
- motion sensor
le type d’éclairage est un simple on/off
- 171 réponses
- Smart Lights
- motion sensor
oui je sais les valeur de mes sondes lux sont bizarre en pleine journée quand beaucoup de lumière dehors mes pièces sont entre 2000 et 3500 lux sur mes sondes (valeur afficher sur la hc2) donc min 2500 lux c'est pour mes test ainsi je suis sur que les lux n’interfère pas dans le script quand cela marchera je baisserai cette valeur
- 171 réponses
- Smart Lights
- motion sensor
alors voici la config des variables : --Enter the name of your Global variable. WITHOUT IT, THE SCENE DOES NOT WORK. Capital sensitive! sleepState = "SleepState"; --Sleep globalstate variable. timeOfDay = "TimeOfDay"; --Time of Day Global variable. presentState = "PresentState"; --Present state Global variable. --Enter the values of your global variables stated above. If not using, copy the name in front of the "YourValueName" sleepStateMapping = {Sleeping="Sleeping", Awake="Awake"}; timeOfDayMapping = {Morning="Morning", Day="Day", Evening="Evening", Night="Night"}; presentStateMapping = {Home="Home", Away="Away", Holiday="Holiday"}; les paramètres lux : -- Set the lux value for which the lights have to be turned on. -- If you don't want to use the MinLux then just set it to: 65535 minLuxMorning = 2500; minLuxDay = 2500; minLuxEvening = 2500; minLuxNight = 2500; --If the current lux value is above the maxlux, the lights will turn off after their set onTime. maxLuxMorning = 3000; maxLuxDay = 3000; les commandes (toutes les même) lightsSleeping = {}; --lights that are triggered when Sleepstate is sleeping. lightsMorning = {{id=73, onTime=300}}; lightsDay = {{id=73, onTime=300}}; lightsEvening = {{id=73, onTime=300}}; lightsNight = {{id=73, onTime=300}}; --Manual Override, the time that lights will not be turned ON again after manually turning them off. OverrideFor = 90; dimmDownTime = 10; je ne comprends pas trop a quoi correspond ceci : OverrideFor = 90; dimmDownTime = 10; mais j'ai laisser par défaut l'etat des variable global PresentState = Home TimeOfDay = Day SleepState = Awake et encore une fois cette ligne dans les log qui me pousse a croire qu'il envoie la commande d'allumage Lights turned: on for Day qui est je crois : lightsDay = {{id=73, onTime=300}}; ou ai-je fait une erreur :-) ?
- 171 réponses
- Smart Lights
- motion sensor
justement j'essaye comme cela : {{id=73, onTime=300}}; le onTime veut dire on allume pendant 300 sec OU on allume aprés 300sec ?
- 171 réponses
- Smart Lights
- motion sensor
bonjour juste pour etre sur, les lignes de log indique : que detecteur mvt a detecter un mouvement les lux sont bien inférieur au lux min commande pour allumer les lumière ? [DEBUG] 10:11:01: Home status: Home [DEBUG] 10:11:01: Motion status: movement [DEBUG] 10:11:01: Triggered by: 42 Motion sensor [DEBUG] 10:11:01: Sensor lux: 500 is lower then minValue: 2500 [DEBUG] 10:11:01: Lights turned: on for Night mais rien ne s'allume... pour être sur de la commande : {{id=73, onTime=300}}; ---> turnOn de l'id 73 pendant 300 seconde puis turnOff ?
- 171 réponses
- Smart Lights
- motion sensor
c'est les varaibles global que je ne comprends pas trop si je fait par ex : sleepState = "SleepState"; --Sleep globalstate variable. timeOfDay = "TimeOfDay"; --Time of Day Global variable. presentState = "PresentState"; --Present state Global variable. --Enter the values of your global variables stated above. If not using, copy the name in front of the "YourValueName" --Entrez les valeurs de vos Variables Globales qui correspondent aux variables ci dessous sleepStateMapping = {Sleeping="Sleeping", Awake="Awake"}; timeOfDayMapping = {Morning="Morning", Day="Day", Evening="Evening", Night="Night"}; presentStateMapping = {Home="Home", Away="Away", Holiday="Holiday"}; donc variable sleepState correspond a sleepStateMapping et dois contenir 2 valeur sleeping et awake ? sleeping veut dire script en sommeil ou alors que les gens dorme ou sont pas la ? et inversement awake? presentState correspond a presentStateMapping et contient les valeur home, away, holliday (qui corrensponde au mode de la maison ? est-ce que ces ligne sont correcte pour allumer une lampe pendant 360 sec : lightsSleeping = {}; --lights that are triggered when Sleepstate is sleeping. lightsMorning = {{id=73, setValue="turnOn", onTime=360}}; lightsDay = {{id=73, setValue="turnOn", onTime=360}}; lightsEvening = {{id=73, setValue="turnOn", onTime=360}}; lightsNight = {{id=73, setValue="turnOn", onTime=360}}; j'ai ça dans les log donc je suppose que c'est plutôt bon mais cela ne s'allume pas [DEBUG] 00:41:50: Home status: Home [DEBUG] 00:41:50: Motion status: movement [DEBUG] 00:41:50: Triggered by: 42 Motion sensor [DEBUG] 00:41:50: Sensor lux: 500 is lower then minValue: 2500 [DEBUG] 00:41:50: Lights turned: on for Night [DEBUG] 00:41:50: © Smart Lights V1.6.7 | by Control Living, Finished [DEBUG] 00:41:50: ------------------------------------------------------- désolé des question un peu bete :-)
- 171 réponses
- Smart Lights
- motion sensor
bonjour, j'ai quelques questions : 1- si j'ai bien compris il faut 1 script par pièce ou on veut gérer l’éclairage ? 2- dans mon installe j'ai un vd qui change 2 variables, 1 variable mode_homestatus et une variable saison suivant la valeur de la variable mode_homestatus cela exécute un scripts qui lui même suivant la saison exécute une liste de fibaro:call() (tout ça c'est pour planter le décor :-) ) la variable global mode_homestatus contient 8 mode différents, j'aimerai que le script s'execute lors des mode suivant : Maison, soirée, nuit, ne pas deranger, manuel et ne s’exécute pas pour les modes : sortie courte, sortie longue, vacances mais suivant une luminosité min pour 4 pieces et sans rapport de luminosité pour 1 piece(ou je n'ai pas de capteur de lux) je ne vois pas comment utiliser ce script du coup je vois bien que cela ce passe dans cette partie mais suis un peu perdu motionSensorID = {477}; -- change id for your motion sensor. LuxSensorID = {480}; -- change id for your light sensor. --Enter the name of your Global variable. WITHOUT IT, THE SCENE DOES NOT WORK. Capital sensitive! sleepState = "SleepState"; --Sleep globalstate variable. timeOfDay = "TimeOfDay"; --Time of Day Global variable. presentState = "PresentState"; --Present state Global variable. --Enter the values of your global variables stated above. If not using, copy the name in front of the "YourValueName" sleepStateMapping = {Sleeping="Sleeping", Awake="Awake"}; timeOfDayMapping = {Morning="Morning", Day="Day", Evening="Evening", Night="Night"}; presentStateMapping = {Home="Home", Away="Away", Holiday="Holiday"}; -- Set the lux value for which the lights have to be turned on. -- If you don't want to use the MinLux then just set it to: 65535 minLuxMorning = 100; minLuxDay = 60; minLuxEvening = 40; minLuxNight = 30; --If the current lux value is above the maxlux, the lights will turn off after their set onTime. maxLuxMorning = 300; maxLuxDay = 300; --[[ Now the most important part: Here you can enter what light, for how long and at what value has to be turned on. Leave empty brackets for no lights. To set the light value without timer use 2 parameters: {id=LightID, setValue="VALUE"} To set the light value with timer use 3 parameters: {id=LightID, setValue="VALUE", onTime=timeInSeconds } To set the light value for RGBW: use the above, where setValue is: setValue={R="255",G="255",B="255",W="255"} -- RGBW set: {id=LightID, setValue={R="255",G="255",B="255",W="255"}, onTime=timeInSeconds } --]] lightsSleeping = {}; --lights that are triggered when Sleepstate is sleeping. lightsMorning = {{id=471, setValue="99", onTime=300},{id=491, setValue="99", onTime=300},{id=902, setValue="turnOn", onTime=360}}; lightsDay = {{id=471, setValue="80", onTime=90},{id=491, setValue="80", onTime=90}}; lightsEvening = {{id=471, setValue="60", onTime=300},{id=491, setValue="60", onTime=300},{id=902, setValue="turnOn", onTime=300}}; lightsNight = {{id=471, setValue="45", onTime=60}, {id=491, setValue="45", onTime=60}}; --Manual Override, the time that lights will not be turned ON again after manually turning them off. OverrideFor = 90; dimmDownTime = 10; et un cas particulier (évidement) la monté d'escalier a 2 détecteurs de mouvement 1 en bas et 1 en haut sur le palier avec un angle entre les 2 je voudrais qu'en mode nuit la lumière de l'escalier ne s'allume uniquement si le détecteur du haut détecte un mouvement alors que dans les autre mode quelque soit le détecteur cela allume la montée ai-je vraiment besoin de la variable : timeOfDayMapping voila j’espère que j'ai été assez clair et que vous pourrais m'aider merci d'avance
- 171 réponses
- Smart Lights
- motion sensor
je viens de faire l’expérience, j'ai activer homebridge et me vd ne réagissaient plus, j'ai fait un reboot de la hc2 et la plus d'action sur les devices... j'ai couper homebridge puis reboot hc2 et tout est revenu a la normal ...
bonjour, merci pour l'info j'ai jeter un coup d'oeil mais je ne compremds pas tout pour le moment je vais me pencher la dessus par contre j'ai ca avec le script gea To many instances | Scene: GEA il y a 12 minutes Number of instances of scene has been reduced due to exceeding limit. voici ce que j'ai rajouter dans le script pour le moment ------------------------- -- Detection de Mouvement ------------------------- -- Détecteur Hall (id 42 = id["MVT_HALL_ENTREE"]) lampe (id 73 = id["SPOT_HALL_ENTREE"]) GEA.add(id["MVT_HALL_ENTREE"], -1, "", {{"turnOn",id["SPOT_HALL_ENTREE"]}}) local mvtHall = GEA.add(id["SPOT_HALL_ENTREE"], 1*60, "", {{"turnOff"}}) GEA.add(id["MVT_HALL_ENTREE"], -1, "", {{"RestartTask", mvtHall}}) -- Détecteur WC (id 41 = id["MVT_WC"]) lampe (id 74 = id["LUMIERE_WC"]) GEA.add(id["MVT_WC"], -1, "", {{"turnOn",id["LUMIERE_WC"]}}) local mvtWC = GEA.add(id["LUMIERE_WC"], 2*60, "", {{"turnOff"}}) GEA.add(id["MVT_WC"], -1, "", {{"RestartTask", mvtWC}}) -- Détecteur WC (id 43 = id["MVT_BUANDERIE"]) lampe (id 72 = id["LUMIERE_BUANDERIE"]) GEA.add(id["MVT_BUANDERIE"], -1, "", {{"turnOn",id["LUMIERE_BUANDERIE"]}}) local mvtBuanderie = GEA.add(id["LUMIERE_BUANDERIE"], 2*60, "", {{"turnOff"}}) GEA.add(id["MVT_BUANDERIE"], -1, "", {{"RestartTask", mvtBuanderie}}) -- Détecteur WC (id 44 = id["MVT_PTIT_BUANDERIE"]) lampe (id 76 = id["LUMIERE_PTIT_BUANDER"]) GEA.add(id["MVT_PTIT_BUANDERIE"], -1, "", {{"turnOn",id["LUMIERE_PTIT_BUANDER"]}}) local mvtBuanderie = GEA.add(id["LUMIERE_PTIT_BUANDER"], 2*60, "", {{"turnOff"}}) GEA.add(id["MVT_PTIT_BUANDERIE"], -1, "", {{"RestartTask", mvtBuanderie}}) -- Détecteur WC (id 40 = id["MVT_CUISINE"]) lampe (id 75 = id["LUSTRE_CUISINE"]) GEA.add(id["MVT_CUISINE"], -1, "", {{"turnOn",id["LUSTRE_CUISINE"]}}) local mvtBuanderie = GEA.add(id["LUSTRE_CUISINE"], 2*60, "", {{"turnOff"}}) GEA.add(id["MVT_CUISINE"], -1, "", {{"RestartTask", mvtBuanderie}}) est-ce mal formuler ? merci
bonjour, je me suis mis a gea :-) et s'est pas mal (même si encore un peu obscure pour le moment :-)) voila ou j'en suis pour une detection de mouvement -- Détecteur Cuisine (id 40) avec allumage de lampe (id 75) -- Chaque détection redémarre le time de la lampe GEA.add(id["MVT_CUISINE"], -1, "", {{"turnOn",id["LUSTRE_CUISINE"]}}) local mvtBuanderie = GEA.add(id["LUSTRE_CUISINE"], 2*60, "", {{"turnOff"}}) GEA.add(id["MVT_CUISINE"], -1, "", {{"RestartTask", mvtBuanderie}}) maintenant j'aimerais faire 2 chose en plus avant d'allumer : 1 au lieu de réagir a la chaque détection, vérifier si pendant par exemple 2 sec que le détecteur soit armer (pour éviter les faux positif) 2 vérifier si la luminosité de la pièce est supérieure a une valeur mais je ne vois pas comment écrire cela merci de votre aide
bonjour, je cherche a faire une scène qui ne s’exécute qu'une seul fois au Boot de la hc2, pour la mise a jour de variable global il me semble que j'avais vu passé un post la dessus mais je ne le retrouve plus si quelqu'un a une solution ou ce fameux post :-) merci
effectivement j'ai aussi un homebridge qui tourne chez moi ce serait-donc lui le coupable ... c'est vrai que depuis le restaure de ma box je n'ai pas réactiver le service hombridge... du coup je me demande si je vais le faire (dommage ça marche pas mal)
voila j'ai réussi (je crois a voir a l'usage) a regrouper dans 1 seul script / pièce s'est déjà ça grace au script : http://www.domotique-fibaro.fr/index.php/topic/4933-settimeout/ de Berale24 (merciiii) --[[ %% properties 53 value 53 armed %% globals --]] -- Variable a modifier local luminosite_min = 2000; local action_device = 108; local mvt_device = 53; local luminosite_device = 67; local mvt = fibaro:getValue(mvt_device, "value"); local luminosite = fibaro:getValue(luminosite_device, "value"); -- La Luminosité est suffisante donc on STOP if (tonumber(luminosite) > tonumber(luminosite_min)) then fibaro:debug("Luminosite Suffisante : " .. luminosite); fibaro:abort(); end fibaro:debug("Start"); local val = fibaro:getValue(mvt_device, "value"); local arm = fibaro:getValue(mvt_device, "armed"); local scenenum = fibaro:countScenes(); fibaro:debug("Etat "..val.." "..arm); fibaro:debug("scene n "..scenenum); -- premier déclanchement du détecteur -- on allume et stop if (val == "1" and scenenum == 1) then fibaro:call(action_device, "turnOn"); fibaro:abort(); end -- déclanchements suivants on attend 120s -- pour éteindre setTimeout(function() local delayedCheck0 = false; local tempDeviceState0, deviceLastModification0 = fibaro:get(mvt_device, "value"); fibaro:debug("Temps écoulé "..os.time() - deviceLastModification0); if (( (tonumber(val) == 0 and tonumber(arm) == 0) ) and (os.time() - deviceLastModification0) >= 120) then delayedCheck0 = true; end if ( delayedCheck0 == true ) then fibaro:call(action_device, "turnOff"); end end, 120000) fibaro:debug("End"); si vous avez des remarque pour optimisé :-) est-il possible de faire cela en GEA j'ai parcouru pas mal de sujet sur le GEA et ça a l'air pas mal mais est-ce que cette fonctionnalité : détection -- on allume -- après X min si personne on éteint merci de votre aide
j'ai essayer avec un if si lampe allumé on va a la fonction off si lampe eteinte on va a la fonction on mais ca passe pas voici le code -- Scene Mouvement Hall Entree On with delai --[[ %% autostart %% properties 53 value %% globals --]] local luminosite_min = 2000; local action = 108; local mvt_device = 53; local mvt = fibaro:getValue(53, "value"); local luminosite = fibaro:getValue(67, "value"); local state_action = fibaro:getValue(action, "value"); fibaro:debug("mvt = " .. mvt .. " et la lampe est : " .. state_action); if(state_action == 0 ) then fibaro:debug("lampe off donc on allume "); setTimeout(function() local delayedCheck0 = false; local tempDeviceState0, deviceLastModification0 = fibaro:get(mvt_device, "value"); if (( tonumber(fibaro:getValue(mvt_device, "value")) > 0 ) and (os.time() - deviceLastModification0) >= 1) then delayedCheck0 = true; end local startSource = fibaro:getSourceTrigger(); if ( ( delayedCheck0 == true ) and ( tonumber(luminosite) < tonumber(luminosite_min) ) or startSource["type"] == "other" ) then fibaro:call(action, "turnOnMouvement") end end, 2000) end if(state_action == 1 ) then fibaro:debug("lampe off donc on eteint "); setTimeout(function() ------ début de la fonction local delayedCheck0 = false; local tempDeviceState0, deviceLastModification0 = fibaro:get(mvt_device, "value"); fibaro:debug("Temps écoulé "..os.time() - deviceLastModification0); if (( (tonumber(val) == 0) ) and (os.time() - deviceLastModification0) >= 120) then delayedCheck0 = true; end if ( delayedCheck0 == true ) then fibaro:call(action, "turnOffMouvement"); end end, 30000) ------- fin de lafonction avec delai de 30 secondes end encore une fois je suis plus que débutant en lua donc ...
bonjour, j'aimerais l'avis des gourou du lua que vous êtes :-) pour le moment j'utilise 2 scènes pour chaque pièce ou il y a un détecteur de mouvement mais j'aimerais rassemblé tout ça dans Une seule scène mais étant nul en lua je galère voici la une scene ON : --[[ %% autostart %% properties 53 value %% globals --]] local luminosite_min = 2000; local action = 108; local mvt_device = 53; local mvt = fibaro:getValue(53, "value"); local luminosite = fibaro:getValue(67, "value"); setTimeout(function() local delayedCheck0 = false; local tempDeviceState0, deviceLastModification0 = fibaro:get(mvt_device, "value"); if (( tonumber(fibaro:getValue(mvt_device, "value")) > 0 ) and (os.time() - deviceLastModification0) >= 1) then delayedCheck0 = true; end local startSource = fibaro:getSourceTrigger(); if ( ( delayedCheck0 == true ) and ( tonumber(luminosite) < tonumber(luminosite_min) ) or startSource["type"] == "other" ) then fibaro:call(action, "turnOn") end end, 2000) et voici une scène off : --[[ %% properties 53 value %% globals --]] local action = 108; local mvt_device = 53; local mvt = fibaro:getValue(53, "value"); local luminosite = fibaro:getValue(67, "value");; local val = fibaro:getValue(mvt_device, "value"); setTimeout(function() local delayedCheck0 = false; local tempDeviceState0, deviceLastModification0 = fibaro:get(mvt_device, "value"); fibaro:debug("Temps écoulé "..os.time() - deviceLastModification0); if (( (tonumber(val) == 0) ) and (os.time() - deviceLastModification0) >= 120) then delayedCheck0 = true; end if ( delayedCheck0 == true ) then fibaro:call(action, "turnOffMouvement"); end end, 120000) ------- fin de lafonction avec delai de 120 secondes --fibaro:debug("End"); tout les avis, aide, commentaire, exemple sont les bien venu :-) merci pour votre aide ps : si quelqu'un a une idée pour avec une seule scène gérer la détection de mouvement dans toutes les pièces il serait mon roi ^^
