50 -
Tout ce qui a été posté par Floflo42
Bonsoir à tous, j'ai finalement trouvé la solutions et je voulais en faire-part si cela peut aider quelqu'un d'autre. Il faut réinitialiser au paramètre d'origine le Qubino (hey oui ! ont perds toutes les anciennes valeurs ) et après vous faite l'inclusion au HC3 et les valeurs remontent correctement. Belle soirée à tous
Qubino ZMNHXD1 3-Phase Smart Meter Pages produit : https://qubino.com/products/3-phase-smart-meter/ https://qubino.com/products/3-phase-smart-meter/smart-meter-3phase-tech/ Main terminals (L1I, L2I, L3I, NO, L1O, L2O, L3O, NO) Contacts capacity: 2.5 ... 16 (25) mm2 Connection screws: M5 Max torque: 3.5 Nm (PZ2) Optional terminals (1,2,4,5) Contact capacity: 1 ... 2.5 mm2 Screws: M3 Max torque: 1.2 Nm Measuring input: Type (connection): three phase (4u) Basic current (Ib): 5 A Maximum current (Imax): 65 A Minimum current (Imin): 0.25 A Starting current: 20 mA Nominal voltage (Un): 3x230 V/400V Power consumption at Un: < 8 VA Nominal frequency (fn): 50 and 60 Hz Accuracy: Active energy and power: Standard EN 62053-21: class 1 Standard EN 50470-3: class B Reactive energy: Standard EN 62053-23: class 2 LED: Colour: red Pulse rate: 1000 imp/kWh LED on: no load indication Optical communication: Type: IR - used to control BICOM432-40-IR Input (16): Rated voltage: 230 V (± 20%) Input resistance: 450 kOhm Safety: LCD: Indoor Meter: yes Degree of pollution: 2 Protection class: II AC voltage test: 4 kV Installation Category: 300 Vrms cat. III AC voltage test: 4 kV Installation Category: 300 VRMS Cat. III Standard: EN 50470 Ambient conditions and EMC: According standards for indoor active energy Meters. Temperature and climatic condition according to EN 62052 11 Ambient conditions and Safety: According standards for indoor active energy Meters. Temperature and climatic condition according to EN 62052 11 Dust/water protection: IP50 Operating temperature: -25 ... 55°C Storage temperature: -40 ... 70°C Enclosure material: self-extinguish complying UL94 V Indoor Meter: yes Degree of pollution: 2 AC voltage test: 4 kV Standard: EN 50470 Distance: up to 30 m indoors (depending on building materials) Weight (with packaging): 220g (240g) Frequency range: 868.4 MHz*, Z-Wave Installation: DIN rail 35mm Dimensions (W x H x D): 53,6 x 84 x 65mm Package dimensions (W x H x D): 58 x 84 x 95mm Colour RAL 7035 ------------------------------------------------------------------------------------------------------------------------------------------------- Bonjour à tous, Je suis en train de refaire (exclure/inclure les modules) l'intégralité de mon réseau domotique maintenant que j'ai ma HC3. Je rencontre quelques petites bizarrerie que j'essaye de comprendre au fur et à mesure. J'ouvre se post/sujet car je n'ai rien trouvé concernant la HC3 & le module Qubino Smart Meter 3-Phase Je l'ai inclus il y a quelques jours mais je n'ai pas de retour des valeurs sur tout les points alors que je les avait sur ma HC2 et se que quelqu'un a déjà eux se problème ??? Voici une capture d'écran ou vous constaterez que je n'ai des retours uniquement sur les Watts .... Merci à tous d'être ici
Bonjour à tous, Alors je voulais juste préciser deux ou trois détails de ce que j'ai pu voir concernant le google nest Hub que j'ai pu voir en me renseignant avant d'acheter : Il y a trois model : Le google Nest hub avec un écran 7'' (SANS Camera donc pas de visiophonie et de reconnaissance des gestes ) Le google Nest hub MAX avec un écran 11'' un son meilleurs 2.1 plus la caméra et il sera pas dispo avant la fin de l'année au mieux à mon avis ET ATTENTION il y a le premier model qui traine encore a plusieurs place c'est le google home hub et lui il faut l'éther car il y a des problème avec les boutons ne sont pas les même et d'après-ce que j'ai compris l'OS n'est pas le même du coup très limité J'ai le miens un Google nest Hub depuis quelques jours et j'ai trouvé très facilement le module Fibaro (bien plus facile que Amazon Alexa à mettre en place ) il m'as trouver sans problème ma box HC2 il m'as ajouté tous les modules ... lumières mais pas le reste et j'ai pas encore trouver pourquoi je n'ai que les lumières. Pour ce qui est de l'état j'ai l'informations si la lumière et allumée ou pas autre détails que j'ai remarqué jusque la j utilisais Amazon Alexa et je ne pouvais pas utilisé mes model dimable et sur le Google home hub ça fonctionne super bien ! En tout cas pour ma pars je me réjouis de découvrir plus de se nouveau gadget Bon Dimanche à tous
Floflo42 a répondu à un(e) sujet de yoim dans Les Assistants Vocaux
Bon j'ai finalement réussi a mettre les Skill mais j'ai du en réaliser réinitialiser ma Amazon Echo et ensuite j'ai suivi cette procédure pour arrivé à la connecter alors que avant cela ne fonctionnais pas https://www.alexafrance.fr/14/06/2018/comment-acceder-au-skills-store-en-francais/ Aller maintenant vais aller tester le résultat ....- 501 réponses
J'ai remodifié l'adresse pour la mettre a Londre mais j'ai toujours rien quand je regarde dans les skis et si je vais manuellement la chercher sur l'amazon store il me met que la situation géographique n'est pas bonne ....- 501 réponses
Bonjour à tous , désolé de revenir a la charge avec cette question qui as déjà été mentionnée dans les page précédentes mais je bloque .... j'essaie de tout passer en anglais compte Amazon et dans Alexa avec une adresse a New-Yord mais impossible de voir les skis Fibaro et le site https://alexa.amazon.co.uk/? me renvoie as chaque fois sur la page .fr ou est ce que j'ai loupé quelque choses ? Merci d'avance pour vos future réponse- 501 réponses
Hello à tous !! Je vous adore !!!!!!!!! J'ai jamais aussi dire quelques choses car l'impression d'être un fou car j'avait vraiment trouver de forum qui en parle .... je vais suivre ce post pour aussi essayer de comprendre. Merci S3B
Topic unique Passer De Qnap À Synology
Floflo42 a répondu à un(e) sujet de jorderic dans Multimédia (audio, vidéo ...)
Hello, nous sommes 4 seuls !! ;-) Pour instant je vais quand même rester sur Qnap car ils ont annoncer des efforts concernant leurs logiciels alors j'attend de voir surtout que le mien tourne comme une horloge et en parfait syncro avec mon réseau et Apple TV ..... j'ose rien toucher pour une fois que tout tourne. Bon Dimanche -
Re, si ont veux normalement il marque qubino et pas Goab dans Fabricant , du coup je n ai pas de retour sur l'état du store si il est ouvert ou fermer ... et aucun paramètre pour la configuration prob qubino 2.tiff
Bonjour, je désespère un peu en ce moment il y a rien qui fonctionne comme ça devrait et quand j'exlu un modus pour le réinclure c'est de pire en pire. J'ai fini par acheter un nouveau module qubino shutter pour essayer et .... il est pas reconnu ????? Avez-vous une idée de mon problème ? prob qubino.tiff Merci de vos future réponse
Bonjour, Alors je me réjouit de voir les réponses .... Car moi je n'ai pas trouver la solutions et fait venir un électricien et m'as simplement répondu que seul un interrupteur peu être installer et pas un variateur. Bonne app'
Ok Mais je ne te cache pas que en Suisse le prix est même plus cher que les D-link. Je pense que je vais rester sur des D-link pour l'intérieur car c'est vrai pas un seul soucis avec la HC2. Mais il faut que je trouve des caméras pour l'extérieur. En France tu la paye combien ? la Foscam FI9805W en suisse elles sont 250.- + frais d'envois 19.-- (environ 224 €)
Topic unique Sonde De Mesure Chlore
Floflo42 a répondu à un(e) sujet de ced600f dans Chauffage et Energie
Bonjour, regarde cette articles il a déjà mis en place ce type de system surveillance pour la piscine. http://clement.storck.me/blog/2014/08/controle-et-supervision-de-la-piscine/ Maintenant il me semble que j'avais vu quelque chose avec la HC2 je recherche, quand je trouve je t'écrit. Bonne journée -
Est ce que quelqu'un connait la marque Digitus ? car leur site n'est même pas a jour en fonction des produits que l'ont retrouve chez les revendeurs
Bonjour, Merci pour vos réponses Lazer : Non je n'avais pas encore vu cette articles et j'ai écrit à Cédric et je vous donnerais sont retour d'informations. Sakkhho : Je pensais bien que ça risquais d'être fermer surtout quand je voit qu'il faut un boitier pour la communication , par contre peux tu m'en dire plus sur les caméra Piper ? Car un de mes revendeur de matériel Domotique me la conseiller car selon lui il y a rien de mieux ..... pour le prix. fab971 : Merci je vient d'étudier un peu tes proposition, les mobotix c'est un jolis produits mais effectivement mon porte-monnaie n'est pas d'accord. Par contre les foscam sont vraiment intéressante mais tu n'as pas de problème avec ? Car j'ai mon papa qui en as une est vraiment compliquer a configurer et en plus l'image et pas net (à mon avis la lentille est mal mise) mais le vendeur lui avais dit que c'est normal pour une camera de ce prix .......
Bonjour à tous ! Pour commencer je vous souhaite un bon Week-end de Pâques. Alors je suis sur le point d'acheter des cameras pour installer dans la maison et aussi à l'extérieur. (Actuellement j'ai des D-link 932L qui ne sont pas étanche ) Suite à mes différentes recherche je suis tomber sur les nouvelles caméra de Netgear Series Arlo et .... j'ai l'impression que c'eat un bon produits. Mais est ce que elles seront compatible avec ma HC2 ? Je suis un peu perdu avec les compatibilités des caméras. Voici le lien du produits : http://www.arlo.com/fr/ Est ce que vous pensez que c'est un bon produit compatible Figaro ?
Enfin !!! C'est ou les commandes ??? Loool
Tuto HC2 Pilotez Votre Qnap Avec La Hc2
Floflo42 a répondu à un(e) sujet de labomatik dans Tutoriels
Bonjour, Enfin du Qnap ... bon faut que j'étudie tous sa ! Mille merci pour cette marche a suivre. -
Besoin daide Création De Scènes Simples Sur Hcl
Floflo42 a répondu à un(e) sujet de couillerot dans HCL
Hello, Pourrait tu mettre problème résolu ? Sa serait sympa pour ceux qui rechercher une informations Bonne fin de week-end -
Je suis d'accord de prendre les modules de la même marque a certain avantage et désavantages aussi ! J'essaie d'avoir un maximum de retour concernant la consommation d'énergie sur chacune de mes prises et bien souvent la température pour cette raison que je passe sur les model Qubino ... Bon dimanche
Bonjour, Concernant le problème Qubino 2 relay - le double relais fait fonctionner les deux sorties en même temps. Est ce que le problème apparait aussi sur la HC2 ou uniquement la HCL ? (J'ai plusieurs module et pour l'instant je ne sais pas trop quoi faire avec ....) Merci de votre future réponse
Bonjour, Ya t'il une réponse concernant cette mise en oeuvre ? Est-ce réalisable avec une hcl ? Bonne journée
Annonce L'équipe Domotique-Fibaro S'agrandit !
Floflo42 a répondu à un(e) sujet de Moicphil dans Annonces et suggestions
Bonjour, Bienvenue dans l'équipe est bon courage !
