Daniel Plantings
    8
Daniel Plantings a gagné pour la dernière fois le 12 avril 2024
Daniel Plantings a eu le contenu le plus aimé !
    Rotterdam
  • Intéret :
    domotica
    Home Center 3
    3
Daniel Plantings's Achievements
  1. Thanks for the tip. The code is really extended, many salutions to you and the original builder, very sophisticated. But yeah, now i have the value and i will send the information that i do get, to the child. I'll see if i can get someone to install the clamps. If i have that, i'll reinstall the QA from start and it will work as it should i'm sure Thank you very much!
  2. Yeah i dont have those installed... So that explains that i dont have the PowerLive meter... But i do have this data: production": [ { "wNow": 1728, this wNow i could push to the child "Child-Prod Live" if it was initialized, but it isnt...
  3. Als ik een ampermetrische haak in mijn elektrische bord heb, weet ik het niet. Hoe kan ik zien? productie.json Is this what you mean? Does this help?
  4. Bedankt! Laten we eerst beginnen met de verschillen. Het lijkt erop dat ik de meter heb gemeten, maar ik weet niet wat het zou afwijken van normaal. Het lijkt geen productie te hebben ("produceren": false,), maar kan ik dit controleren op de fysieke Envjoy box? Envoy-S-Metered-EU SKU: ENV-S-EM-230 Misschien zegt dit al genoeg? { "devices": [ { "img_pnum_running": "520-00086-r01-v02.12.11", "admin_state": 1, "device_control": [ { "gficlearset": false } ], "chaneid": 1811939601, " line3-connected": true, "line2-connected": true, "img_load_date": "1529083534", "part_num": "800-00597-r02", "line1-connected": true, "provisioned": true, " communiceren": true, "reason": "ok", "dev_type": 12, "reason_code": -1, "geïnstalleerd": "1678364881", "relay": "gesloten", "serial_num": "122251029694", "line-count": 3, "created_date": "1678364881", "producing": false, "ptpn": "540-00139-r01-v02.12.00", "last_rpt_date": "1713947689", "device_status": [ "envoy.global.ok" ], "operationeel": true } ], "type": "NSRB" }
  5. Hi TitiXsi, yes i've watched movie, it initializes most children, just not the Child-Prod Live and a few others... Looks like i dont have production? But i dont understand why it does not create the placeholder on initiation...
  6. Hi @TitiXsi, Awesome job, to me, super complicated code, but it works awesome. That said the Child-Prod Live child is not created, you also mention something about it in your starting post. How do i initialize it? Do i manually need to create it?
  7. Je viens de rejoindre le forum. Excellent contenu ! Malheureusement, je ne parle pas bien français, mais je peux traduire sur Google. Je suis principalement intéressé par l'application rapide pour Envoy de TitXsi !
