Yoxxx
    3
Tout ce qui a été posté par Yoxxx
  1. You are welcome, many thanks on my side. I have modified my QA with adjustments and everything works fine. Just a question, is there a reason why you don't allow "Auto" in thermostat modes? I made it available as well as other minor things (Set_Split_Data("VaneHorizontal",8) for units which can split the Vanes to both sides etc. Not sure about Auto mode in general, thats why I am asking. I just wanted to have all the MELCloud options in Fibaro as well.
  2. Greetings from Czech Republic and many thanks for the QuickApp provided. I got the conection working, let me add here: - for people with diacritics in their language as in czech, it seems you cannot use charcters like "ý, ž, í, č" etc. in MELCloud setup, otherwise Fibaro QA will not find it and it will quite quicky disable your MELCloud probably due to many connection attempts. - On top of that, if you already added your split with the use of such characters, be sure to remove from MELCloud nad add it once again. Simple renaming was not working for me. after that - I can confirm 2 minutes timeout works well The only issue I came across currently is: - I cannot set the Vane horizontaly or vertically, what it does is it sends the command to MELCloud, even MELCloud app shows the change of the vane position for a while, but AirCon unit does nothing and after while MELCloud status changes back to previous state. Other way around everything works fine, when I change vane position from MELCloud, Fibaro QA gets it correctly. Any ideas?
  3. Zdravím vás z České republiky, dostávám Mitsubishi Air Condition a mám velký zájem o MELcloud QuickApp, o kterém zde diskutujete!
