High end mattress toppers - Memory foam?
Not all memory foam mattress toppers are of high quality. It will not be easy to find a topper which can both customize the mattress, extending its lifetime of use and bring comfort to your sleeping time. Let us see the benefits and limitations in Best Mattress Topper Review.
Advantages of using memory foam mattress toppers
Because of excellent motion isolation, the foam topper limits motion transfer. When you put one on top of the mattress, whether it is innerspring, latex, or hybrid, it will create a sound sleep experience. The foam topper is one of the cures for acute pressure. It can contour your body nicely and it springs back faster than others. Also, the foam product is hypoallergenic. Thus we don’t need to consider the harmful chemicals you’re being exposed to in your sleep. Even if you are an allergy sufferer, foam is the best choice.
Limitations
Although the foam topper is not as cool as others because it is not made of the same cooling material, it can combine with some other materials such as gel, charcoal, or copper. Also, the foam might have an off-gassing smell when it is new. This smell will disappear quickly if you have a high-end quality foam topper. The foam topper is generally also a little heavy, especially the thicker ones.
Many brands of foam mattress toppers try to address user’s consideration with memory foam by combining it with other materials such as copper, charcoal, or gel for more sleep benefits.
1.Copper
Copper foam is a temperature regulating material; the copper is antimicrobial and offers more support and pressure relief than the traditional memory foam toppers.
2.Gel
You might know a lot of toppers which have gel infused memory foam. The gel is a cooling pack that prevents you from sweating miserably while you sleep. Gel foam was introduced for the first time eight years ago. Now, it is becoming more and more popular for preventing foam from overheating users, which makes these memory foam toppers the best topper for bed.
See Also: The best mattress toppers: improve your mattress and sleep better
3.Charcoal
You might be a little concerned about how charcoal could be in foam. Charcoal is one of the best things for neutralizing odors and regulating moisture which are limitations that foam sleepers have to face due to excessive heat. As you know, after burning a bamboo tree in high temperature heat, there remains the bamboo charcoal. Most foam toppers use that charcoal powder for their foam topper. Charcoal is one of the best natural materials that is eco-friendly to sleeper’s health.
4.Graphite
This material has been used for a long time. It can transfer heat away from our bodies quickly. Also, it dissipates the heat out of the mattress as soon as possible.
We’ve showed you some pros and cons of memory foam mattress toppers, one of the Best Rated Mattress Topper Thekinglive on the market. We hope you are now more alert to be able to make your purchase.
Decide which topper would be the best for you, trying your personal preference first. Some people need several times to get the right one, and some require a lot of time without ever making any decision. Read more mattress topper reviews. Genuine feedback from users is one of the best ways to find the best product to buy.
Source: http://molbiol.ru/forums/index.php?showtopic=590220
Follow TheKingLive for more information about products
