jnevestdl
    7
    Tondela, Portugal
  • Intéret :
    Fibaro, Domotique, Helios IP Force, SMA Sunny Boy, SMA Sunny Island, SMA Home Manager 2.0, iAqualink, eXO IQ
    Home Center Lite
    HC2 4.570 + HC Lite 4.120
jnevestdl's Achievements
  1. Bonjour, J'aimerais pouvoir utiliser les donnees de EMONCMS, pour affiche le Live Data de: Import Use Solar Sur un seule VD ou alors mieux que ca, comme module virtuel independant, comme ca je pourrais faire des "Magic Scenes" Le lien json que j'ai: http://IP-du-emoncms/emoncms/feed/value.json?id=26&apikey=xxxxx (import) http://IP-du-emoncms/emoncms/feed/value.json?id=25&apikey=xxxxx (solar) http://IP-du-emoncms/emoncms/feed/value.json?id=29&apikey=xxxxx (use) Merci d'avance.
  2. Hi, Now that we are in 2017... I bought a Netatmo Thermostat, created the dev account, but it says "connected" but I can't get the devices... Is really necessary to use a virtual device for netatmo thermostat? If I buy a Wether Station, will it be easy to use the plugin? Can I use the Netatmo thermostat to be controlled on the Fibaro Heating Panel? Thanks in advance for your answers.
  3. jnevestdl
    HC2 Bricked
    I've got an cron failed output when it loads the shell. cat: /var/run/cron.pid: no such file or directory Starting periodic command scheduler: cron failed!
  4. jnevestdl
    HC2 Bricked
    Guys. First of all thank you very much for your ideas. @971jmd Did not work. It's not the case apparently. @jojo Does not work either. @Fanou Recovery mode does not work. I plugged a monitor to the VGA port and what can I see is the following... I tried to force the boot using the USB Recover Key did not work. I have access to the shell, but I don't know the login. What do you think could be guys? Is there any way to check the USB Key to see if it is ok or/and make a new one and take the Backups from it? Thanks in advance again.
  5. jnevestdl
    HC2 Bricked
    Bonjour, I write in English because my written French is very bad,but you can write in French, I understand it! I hvae my HC2 bricked after the last update. Can someone help me? This is my issue: Thanks in advance!
  6. Bonjour a tous. Excusez moi pour mon Francais! Que pensez-vous de ces modules? Il utilize les modules Fibaro, mais sont une solution plus professionnel que utilizer les boitiers CamdBoss par exemple! http://x10modules.com/shop/default.php?cPath=74_98 Donnez moi votre opinion svp. Merci!
  7. Hi. I know how to read french, but I don't know how to write... I will try with the google translate on my post. I've got an HC2 with some devices. Tks
