FiftyBen
    Montmorency
    Home Center Lite
FiftyBen's Achievements
  1. et J'en profite pour partager le json du smoke sensor : {"id":7,"name":"smoke sensor","roomID":235,"type":"com.fibaro.zwaveDevice","baseType":"com.fibaro.device","enabled":true,"visible":false,"isPlugin":false,"parentId":1,"remoteGatewayId":0,"interfaces":["battery","zwave","zwaveAssociation","zwaveConfiguration","zwaveMultiChannelAssociation","zwaveSlaveRouting","zwaveWakeup"],"properties":{"associations":"[{\"endPointId\":0,\"groups\":[{\"groupInfo\":{\"commands\":[],\"name\":\"\",\"profile\":\"\"},\"id\":1,\"multiChannel\":{\"bitAddressable\":false,\"max\":1,\"set\":[],\"view\":[]},\"singleChannel\":{\"max\":0,\"set\":[1],\"view\":[1]}},{\"groupInfo\":{\"commands\":[],\"name\":\"\",\"profile\":\"\"},\"id\":2,\"multiChannel\":{\"bitAddressable\":false,\"max\":10,\"set\":[],\"view\":[]},\"singleChannel\":{\"max\":0,\"set\":[],\"view\":[]}},{\"groupInfo\":{\"commands\":[],\"name\":\"\",\"profile\":\"\"},\"id\":3,\"multiChannel\":{\"bitAddressable\":false,\"max\":10,\"set\":[],\"view\":[]},\"singleChannel\":{\"max\":0,\"set\":[],\"view\":[]}},{\"groupInfo\":{\"commands\":[],\"name\":\"\",\"profile\":\"\"},\"id\":4,\"multiChannel\":{\"bitAddressable\":false,\"max\":10,\"set\":[],\"view\":[]},\"singleChannel\":{\"max\":0,\"set\":[],\"view\":[]}},{\"groupInfo\":{\"commands\":[],\"name\":\"\",\"profile\":\"\"},\"id\":5,\"multiChannel\":{\"bitAddressable\":false,\"max\":10,\"set\":[],\"view\":[]},\"singleChannel\":{\"max\":0,\"set\":[],\"view\":[]}}]}]","batteryLevel":"10","batteryLowNotification":"true","categories":"[\"other\"]","configured":true,"dead":"false","deadReason":"","defInterval":"0","deviceControlType":"0","deviceIcon":"28","deviceSpecificData":"h'010f","deviceSpecificIdType":"OEM factory default Device ID Type","deviceState":"Configured","emailNotificationID":"0","emailNotificationType":"0","endPointId":"0","lastWorkingRoute":"[1,5]","lastWorkingRouteRequestStatus":"ok","lastWorkingRouteRequestTimestamp":"0","lastWorkingRouteResponseTimestamp":"1577135599","log":"","logTemp":"","manufacturer":"","markAsDead":"true","maxInterval":"0","minInterval":"0","model":"","neighborList":"[1,5]","neighborListRequestStatus":"ok","neighborListRequestTimestamp":"0","neighborListResponseTimestamp":"1577135598","nodeId":"3","parameters":[{"id":1,"size":1,"value":2},{"id":2,"size":1,"value":0},{"id":3,"size":1,"value":0},{"id":4,"size":1,"value":0},{"id":10,"size":1,"value":0},{"id":11,"size":1,"value":255},{"id":12,"size":1,"value":0},{"id":13,"size":1,"value":0},{"id":20,"size":2,"value":1},{"id":21,"size":1,"value":10},{"id":30,"size":1,"value":55},{"id":31,"size":2,"value":1},{"id":32,"size":2,"value":180}],"parametersTemplate":"323","pollingTimeSec":0,"productInfo":"1,15,12,2,16,2,3,1","pushNotificationID":"0","pushNotificationType":"0","remoteGatewayId":"0","saveLogs":"true","serialNumber":"","smsNotificationID":"0","smsNotificationType":"0","stepInterval":"0","useTemplate":"true","userDescription":"","wakeUpTime":21600,"zwaveCompany":"Fibargroup","zwaveInfo":"3,3,99","zwaveSoftwareVersion":"{}","zwaveVersion":"3.1"},"actions":{"getLastWorkingRoute":0,"getNeighborList":0,"getParameter":1,"reconfigure":0,"requestNodeNeighborUpdate":0,"setInterval":1,"setParameter":2},"created":1577135527,"modified":1577135527,"sortOrder":6}
  2. Hello @Domotique-Home, j'ai installé le plugin et tout marche parfaitement. J'ai cependant un seul problème concernant mes deux wall plugs. A la création dans Jeedom, aucune commande n'est remonté. Je n'ai vu aucune remarque de ce genre dans les échanges précédents. Voici le json d'un des deux WP : {"id":6,"name":"Lampe","roomID":228,"type":"com.fibaro.FGWP102","baseType":"com.fibaro.FGWP","enabled":true,"visible":true,"isPlugin":false,"parentId":5,"remoteGatewayId":0,"interfaces":["deviceGrouping","energy","fibaroFirmwareUpdate","light","power","zwave","zwaveAlarm","zwaveMultiChannelAssociation"],"properties":{"parameters":[{"id":1,"size":1},{"id":2,"size":1},{"id":3,"size":2},{"id":10,"size":1},{"id":11,"size":1},{"id":12,"size":2},{"id":13,"size":2},{"id":14,"size":2},{"id":15,"size":1},{"id":20,"size":1},{"id":21,"size":2},{"id":22,"size":2},{"id":23,"size":1},{"id":24,"size":2},{"id":30,"size":1},{"id":31,"size":1},{"id":32,"size":2},{"id":40,"size":2},{"id":41,"size":1},{"id":42,"size":1},{"id":43,"size":1},{"id":50,"size":1}],"pollingTimeSec":0,"zwaveCompany":"Fibargroup","zwaveInfo":"3,4,24","zwaveVersion":"3.2","alarmLevel":"0","alarmType":"0","categories":"[\"lights\"]","color":"white","configured":true,"dead":"false","deadReason":"","deviceControlType":"5","deviceGroup":"[6,42]","deviceGroupMaster":"42","deviceIcon":"125","emailNotificationID":"0","emailNotificationType":"0","endPointId":"0","energy":"0.04","firmwareUpdate":"{\"info\":\"\",\"progress\":0,\"status\":\"UpToDate\",\"updateVersion\":\"3.2\"}","icon":"{\"path\":\"fibaro/icons/com.fibaro.FGWP_EU/plug1.png\",\"source\":\"HC\"}","isLight":"true","log":"","logTemp":"","manufacturer":"","markAsDead":"true","model":"","nodeId":"2","parametersTemplate":"741","power":"3.50","productInfo":"1,15,6,2,16,3,3,2","pushNotificationID":"0","pushNotificationType":"0","remoteGatewayId":"0","saveLogs":"true","serialNumber":"h'00000000000232a1","showEnergy":"true","smsNotificationID":"0","smsNotificationType":"0","updateVersion":"","useTemplate":"true","userDescription":"","value":"true"},"actions":{"abortUpdate":1,"reconfigure":0,"reset":0,"retryUpdate":1,"startUpdate":1,"turnOff":0,"turnOn":0,"updateFirmware":1},"created":1577135527,"modified":1577135527,"sortOrder":5} Par avance merci!
