roberto.rattin@gmail.com
    5
    arco
    4.530
roberto.rattin@gmail.com's Achievements
  1. Great! Did you solve the problem! Strange because it was the conversion of a block scene .. Thanks a lot!
  2. Here is my problem: I have to create a scene for my greenhouse that lets me start a heater and so far everything is simple. I have a smart meter and I would like the heater to start only under certain conditions such as temperature type below 15 degrees, in a certain amount of time and consumption in watts less than 2900W. No problem for the temperature and time interval but when I enter the consumption the scene "stripping". Transforming a block scene I made this code that seems to work but actually runs only once even if there is the autostart. What am I doing wrong? Here is the lua code I am setting up: --[[ %% autostart %% properties 551 value 719 energy meter %% weather %% events %% globals --]] local energyMeterID = 719 local sourceTrigger = fibaro:getSourceTrigger(); function tempFunc() local currentDate = os.date("*t"); local startSource = fibaro:getSourceTrigger(); powerNow=api.get("/energy/now-1/now/single/devices/power/"..energyMeterID) if ( ( (tonumber(os.date("%H%M")) >= tonumber(string.format("%02d%02d", "16", "00")) and tonumber(os.date("%H%M")) <= tonumber(string.format("%02d%02d", "08", "59"))) and (math.floor(os.time()/60)-math.floor(1550131200/60))%1 == 0 ) and ( tonumber(fibaro:getValue(551, "value")) <= 15 and powerNow.W <= 2900 ) ) then fibaro:call(619, "turnOn"); end setTimeout(tempFunc, 60*1000) end if (sourceTrigger["type"] == "autostart") then tempFunc() else local energyMeterID = 719 local currentDate = os.date("*t"); local startSource = fibaro:getSourceTrigger(); powerNow=api.get("/energy/now-1/now/single/devices/power/"..energyMeterID) if ( ( (tonumber(os.date("%H%M")) >= tonumber(string.format("%02d%02d", "16", "00")) and tonumber(os.date("%H%M")) <= tonumber(string.format("%02d%02d", "08", "59"))) ) and ( tonumber(fibaro:getValue(551, "value")) <= 15 and powerNow.W <= 2900 ) or startSource["type"] == "other" ) then fibaro:call(619, "turnOn"); end end
  3. Hello everyone! News with the api 2.0? did you manage to create a virtual device? Thank you!
  4. Hello everyone!
