maza
    6
Tout ce qui a été posté par maza
  1. good day, @Krikroff did you use latest version of HC (4.160 or 4.161) so to check if this plugin is working? If you did not want to upgrade your HC2, i can provide access to mine for investigation/troubleshooting hoping to solve the problem and may help other people that may get the same issue.
  2. @Krikroff, plugin was installed after upgrade. when I try to remove plugin, it is gone from installed plugins but it stays on the available plugins. Is this normal? After remove and upload/install again, still it gets "Polling is stopped". I press the force restart button of plugin and still no action Is there a way to fully remove plugin and perform fresh install? Does any other people reported that plugin is working on 4.160? Thank you!
  3. Thank you Krikroff for help and for thesse plugins you share! In my case it did not work I double checked the link (it is a domoticz server) and the JSON Syntax. I put 30 sec period in polling. I still get the error like before" Polling is stopped ". Do I lost something on translation? I used the workaround to install plugin and started to build a new device from plugin panel. thanks!
  4. Bonjour! Excuse me that I write in English. Is this plugin still working on 4.106? I have an error on a json power meter, using on field S1 '/result/usage {(%d*)}'. ip and port are correct. Any suggestion? (you can write in French, I will use google translate :P) merci! { "ActTime" : 1518530873, "ServerTime" : "2018-02-13 16:07:53", "Sunrise" : "07:19", "Sunset" : "17:59", "result" : [ { "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 255, "CounterToday" : "0.242 kWh", "CustomImage" : 0, "Data" : "4033.021 kWh", "Description" : "", "Favorite" : 0, "HardwareID" : 5, "HardwareName" : "PVoutput", "HardwareType" : "PVOutput (Input)", "HardwareTypeVal" : 30, "HaveTimeout" : false, "ID" : "00000002", "LastUpdate" : "2018-02-13 16:05:23", "Name" : "SolarConsumed", "Notifications" : "false", "Options" : "", "PlanID" : "0", "PlanIDs" : [ 0 ], "Protected" : false, "ShowNotifications" : true, "SignalLevel" : "-", "SubType" : "kWh", "SwitchTypeVal" : 0, "Timers" : "false", "Type" : "General", "TypeImg" : "current", "Unit" : 1, "Usage" : "793.0 Watt", "Used" : 1, "XOffset" : "0", "YOffset" : "0", "idx" : "12" } ], "status" : "OK", "title" : "Devices" }
  5. Hello to all french people! Nice to be here and get some skills on french too.
