GINOUX DEFERMON
    5
À propos de GINOUX DEFERMON
  • Date de naissance 14/10/1969
    BOURG LA REINE
  • Intéret :
    HOME CENTER 3
    Autre
    5.130.64
GINOUX DEFERMON's Achievements
  1. Cela fonctionne avec hub.call(306, "setColor", 255, 255, 0, 55) Merci Barelle et à votre communauté :-) Un peu dûr quand même le passage au HC3...
  2. OK Merci à vous mais hélas pour moi la commande ci-dessous ne fonctionne pas non plus....Sans doute ma syntaxe n'est pas correcte. hub.call(306, "setColor", "255", "255", "0", "55")
  3. Merci jojo Je pense que je ne suis plus très loin grâce à toi. Mais si je regarde le json de l'ampoule connectée via http://192.168.1.36/api/devices/306, j'obtiens en réponse { "id": 306, "name": "AmpouleSALONCouleurs", "roomID": 230, "view": [ { "assetsPath": "", "name": "com.fibaro.colorController", "translatesPath": "/assets/i18n/com.fibaro.colorController", "type": "ts" } ], "type": "com.fibaro.colorController", "baseType": "com.fibaro.multilevelSwitch", "enabled": true, "visible": true, "isPlugin": false, "parentId": 243, "viewXml": false, "hasUIView": false, "configXml": false, "interfaces": [ "light", "zwave" ], "properties": { "parameters": [], "pollingTimeSec": 0, "zwaveCompany": "Aeotec Limited", "zwaveInfo": "3,4,38", "zwaveVersion": "2.0", "categories": [ "lights" ], "color": "0,252,21,0", "colorComponents": { "blue": 21, "green": 252, "red": 0, "warmWhite": 0 }, "configured": true, "currentProgram": 0, "dead": false, "deadReason": "", "deviceControlType": 51, "deviceIcon": 15, "deviceRole": "Rgb", "endPointId": 0, "icon": {}, "isLight": true, "log": "", "logTemp": "", "manufacturer": "", "markAsDead": true, "model": "", "nodeId": 53, "parametersTemplate": "0", "productInfo": "3,113,0,3,0,2,2,0", "saveLogs": true, "serialNumber": "h'ffffffffffffffff", "state": false, "supportedDeviceRoles": [ "Rgb", "Rgbw" ], "useTemplate": true, "userDescription": "", "value": 0 }, "actions": { "reconfigure": 0, "setColor": 1, "setColorComponents": 1, "setValue": 1, "startColorEnhancement": 1, "startColorFade": 1, "stopColorChange": 1, "toggle": 0, "turnOff": 0, "turnOn": 0 }, "created": 1670954800, "modified": 1670954846, "sortOrder": 110 } Donc pour modifier sa propriété "color": "0,252,21,0" Quelle devrait être la commande LUA ? hub.call(306, "updateProperty","color","255,255,0,0") ne fonctionne pas. Dois-je encoder en json ?
  4. Bonjour Je suis un heureux possesseur de HC3 et ai réussi à migrer mes 33 objets connectés :-) J'ai besoin de votre support pour l'ampoule connectée Aeotec LED BULB pour gérer mon alarme quand on rentre chez moi (scénario basique : ampoule allumée en rouge si l'alarme est activée, ampoule allumée en vert si l'alarme est désactivée) J'ai réussi : - à allumer l'ampoule en LUA via l'action hub.call(id-de-l-ampoule, 'turnOn') - à éteindre l'ampoule en LUA via l'action hub.call(id-de-l-ampoule, 'turnOff') En revanche, je ne sais pas changer les couleurs de l'ampoule car cela nécessite que je change les paramètres propriétés Z-wave de l'ampoule. J'ai trouvé un post relatif au HC2. J'imagine qu'il y a une commande en LUA pour le HC3 pour envoyer des paramètres mais je ne l'ai pas trouvée. Pouvez-vous m'aider ? Merci à la communauté
  5. Bonsoir Je suis un nouvel utilisateur de FIBARO Home Center 2. J'ai commencé la domotique il y a 7 ans avec une centrale ZIBASE 2S de ZODIANET qui fonctionnait bien mais qui ne pouvait plus recevoir de nouveaux équipements avec la mise en faillite de ZODIANET. J'ai donc migré l'ensemble de mes équipements z-wave (FIBARO pour la gestion du chauffage avec fil pilote, EVERSPRING pour les radars avec éclairage terrasse , FIBARO pour les détecteurs d'ouverture de porte-fenetres et la sirène) sur Home Center 2 après pas mal de galères je dois bien l'avouer... Maintenant mon dispositif est stabilisé mais je veux ajouter le TextToSpeech pour remplacer mon lapin KAROTZ par une enceinte SONOS et pouvoir jouer des messages vocaux dans mes différentes "scènes". Bonne soirée Bruno
