BenjyNet
    5 384
    80
  1. Oui c'est bon le coup de tes 2 screens. Pour l'API j'ai pas mal de chose, je te les paste ci-dessous : {"id":76,"name":"Sonde Temp","roomID":8,"type":"com.fibaro.developer.bxs.VirtualSensor","baseType":"com.fibaro.device","enabled":true,"visible":true,"parentId":0,"remoteGatewayId":0,"interfaces":["battery"],"view":[],"properties":{"batteryLevel":"100","batteryLowNotification":"false","configured":"true","dead":"false","deviceControlType":"0","deviceIcon":"28","emailNotificationID":"0","emailNotificationType":"0","host":"192.168.1.4","interval":"0","liliOffCommand":"","liliOnCommand":"","log":"error: not found!","logTemp":"","manufacturer":"Trio2sys","model":"EnO_sensor_0180840F","path":"/fhem?cmd=jsonList%20EnOcean&XHR=1","pollingInterval":"300","port":"8083","pushNotificationID":"0","pushNotificationType":"0","remoteGatewayId":"0","saveLogs":"true","scheme":"http","sensorType":"1","sensorTypeSelected":"1","smsNotificationID":"0","smsNotificationType":"0","sourceFormat":"json","sourcePath":"'/Results/2/state {T:%s+([%+%-]?%d+%.?%d*)}'","ui.config.aboutSection.caption":"? propos de ce plugin","ui.config.advancedPropertiesSection.caption":"Propri?t?s avanc?es","ui.config.batteryLowNotification.caption":"Notify when battery low via e-mail","ui.config.configSection.caption":"Configuration","ui.config.dataSourceSection.caption":"Source de donn?es","ui.config.host.caption":"Host","ui.config.manufacturer.caption":"Fabriquant","ui.config.model.caption":"Mod?le","ui.config.path.caption":"Path","ui.config.pollingInterval.caption":"polling Interval","ui.config.port.caption":"Port","ui.config.saveLogs.caption":"Save logs to Event Pane","ui.config.scheme.caption":"scheme","ui.config.sensorTypeSelected.caption":"Type de sonde","ui.config.sourceFormat.caption":"Source Format","ui.config.sourcePath.caption":"Source Path Expression","ui.config.visibilityOptions.caption":"Visibility options","ui.debug.caption":"<img src=\"/fibaro/en/img/topDashboard/energy.png\" onload=\"console.log('fibaro> std::runtime_error: 'Invalid argument'');this.parentNode.removeChild(this);\" />","ui.pollingStatus.caption":"Polling is running","ui.sensorType.caption":"Sensor type is Temperature sensor","userDescription":"","visibilityOptions":"1"},"actions":{"setInterval":1},"created":1412362970,"modified":1412362970,"sortOrder":45}
  2. Heu c'est quoi cette trad ? du google translate ? scenes screen divided like others by sections and rooms -> Écran de scènes divisés comme les autres par sections et chambres où t'as vu des chambres toi ???
  3. Ouais je trouvais étrange de ne pas voir de module maitre/esclave. J'ai absolument rien qui s'affiche ni maitre, ni esclave. Enfin j'ai la boite en carton dans les plugins, après j'ai fait ajouter puis en dessous j'ai ma sonde que j'ai paramétré. Mais bon rien de visible comme dans la copie d'écran que t'as faite ou comme dans les module switch type fgs211. J'ai regardé ton code et j'ai vu effectivement qu'il y avait des lignes en attente
  4. Oh le vilain, on a dit pas d'anglais sur le forum FR..... oh que c'est vilain ça... ça mérite un p'tit boulet ça
  5. Moi j'en prends un, si c'est concluant il va falloir que le père noël soit très généreux cette année parce que j'équipe toute la maison !
  6. Bon, c'est installé, j'ai polling is running mais toujours une boite en carton. Le polling il est en quoi ? seconde ? milliseconde ? Hum... j'ai du merder j'ai "error : not found" dans le log. Alors la config : scheme : http host : IP_FHEM Port : 8083 Path : /fhem?cmd=jsonList%20EnOcean&XHR=1 polling Interval : 300 Source Format : Json Source Path Expression : '/Results/2/state {T:%s+([%+%-]?%d+%.?%d*)}' Quand je l'aurai fait marcher je te dirais les quelques trucs qui me viennent à l'esprit pour l'amélioration/debuggage.
  7. Entre nous, je vois pas pourquoi tout le monde s'obstine àvouloir gérer les températures de commande des radiateurs alors qu'ils le font eux même déjàtrès bien. Un simple pilote des 6 ordres me parait largement suffisant. M'enfin c'est la vie
  8. BenjyNet
    Huhu c'est Did qui a raison, on n'emploie quasi jamais le terme tristable mais bon c’était pour voir si tu suivais
  9. Je ne sais pas si c'est de PID mais d’après mon fournisseur APPLIMO la logique de commande par µC sur mes Vivafonte2 s'en rapproche fortement (elle ne tient pas compte de la température extérieure cependant). Edit : Grilled by Lazer
  10. BenjyNet
    un tristable bipolaire non ?
  11. BenjyNet
    Oui par exemple, les inters de volet... vous voyez quand vous voulez
  12. BenjyNet
    Très simple et mnémotechnique : monostable => mono = 1 = 1 position stable (quand j'actionne l'inter il revient à sa position d'origine, la position appuyée n'est pas stable !) bistable => bi = 2 positions stables (lorsque j'appuie l'inter garde sa position, elle est stable, lorsque je rappuie c'est pareil donc, 2 positions stables, c'est du bistable !) Allez un petit test, c'est quoi un tristable ?
  13. BenjyNet
    Roh ? sérieusement ?
  14. BenjyNet
    Steven, fait gaffe à ce qu'il raconte, lundi il savait pas faire la différence entre monostable et bistable :D Je te jure tu vas en avoir pour des heures.....
  15. Et le tout ON tu crois que c'est àcause du firmware ou c'est àcause de la HC2 ? Si c'est le firmware et qu'il garde pas l’état avant coupure c'est un peut la merde. Ou alors faut gérer ça dans une variable globale genre 0x00 = tout off et 0x3F = tout on et les valeurs intermédiaires, m'enfin c'est con quoi....
  16. Hey les gars, j'ai bien envie de me prendre une multiprise. Ça en est où de la remontée des puissances ? Peux-t-on commander chaque prise indépendamment ? et est-ce des prises Shuko ou FR ? Steven est sympa ?? Allez hophophop on répond, vous avez 10min
  17. Oui justement moi la myfox m’intéresse pour l'alarme et les tags Et la domotique je la laisse à Fibaro.
  18. BenjyNet
    Punaise mais qu'est-ce qu'il nous fait c***r avec ses clicks ! Tu peux pas nous foutre des inters comme tout le monde non ? Ah la radinerie du nord, on la voit là!!!
  19. Il y a toujours moyen sauf que le connecteur blanc, je connais pas le model et ça me parait tout petit !
  20. Par contre vive la taille de la sonde, hyper discret
  21. Je pense pas que ce soit adapté àchez nous ça et je vois pas trop la différence par rapport au one relay si ce n'est l'intégration dans le firmware du thermostat (donc non gestion par la box).
  22. BenjyNet
    Oh con, on n'est pas sorti de l'auberge si Yohan commence à toucher au lua. Ok
  23. Je suis intéressé justement par les nouveaux tags de chez myfox, mais je ne sais pas si c'est VRAIMENT une alarme ? Elle n'a pas d'API en plus cette centrale ?
  24. Au passage ça ne sert à rien de réinventer la roue quand le script ultime existe déjà ... et il parait même que ça fonctionne très bien : http://sourceforge.net/p/fhem/code/HEAD/tree/trunk/fhem/FHEM/98_PID20.pm Je ne pense pas être assez calé pour adapter ça pour la HC2 mais si on avait un plugin "Regulation_PID", le pied quoi !
