PdB Posté(e) le 27 juin 2016 Signaler Posté(e) le 27 juin 2016 Bonjour, voilà du nouveau.. qui se lance???? Liste des modifications de la version beta 4.083: Version 4.083 BetaThis update features migration process from version 3.600, reconfiguring every device, adjusting it for changes which took place in the system. This will assure possibly smooth transition and continuous operation, allowing each device to work with old settings until reconfiguration is done. Please refer to message that appears in interface and Notification Center after finishing upgrade for further instructions.Important!Updating from version 3.600 may take longer than usual, up to 30 minutes, please do not restart controller during update process.Resolved issues:- Philips Hue plugin does not allow new user configuration. Reinstall existing plugin to enable fix- Wind speed available in weather conditions computed incorrectly - value too low- Services Restart called from 503 error page not working- Multiple Virtual Devices working simultaneously may cause 503 error- Virtual Devices hang- Scenes do not trigger when RAM usage is above 75%. Threshold moved to 90%- Device hierarchy not displaying properly for Dimmer 2 in advanced configuration- FIBARO Swipe imported by Gateway Connection not working properly- Z-Wave Weather templates lacking for devices of other manufacturers- Other minor fixesOther improvements:- Firmware Update - wireless update of Z-Wave devices: Motion Sensor, Dimmer and Wall Plug. Availability of update for each device is showed in Notification Center and Advanced Configuration. Run update only when devices is in close range from controller (ca. 2 m). Process can take up to 30 minutes, depending on Z-Wave traffic and devices queued for update. Details on whole procedure can be found in notification displayed before every device update.- New, configurable scenes triggering modes available in each scene advanced configuration:Automatic - scene gets triggered either by one of defined triggers (device state, global variable etc.) or manually, by 'Run' buttonManual - scene executes only manually by 'Run' buttonDisabled - scene is inactive, does not get triggered and cannot be run manuallyVisibility - scene can be hidden in all interfaces (mobile apps, web interface). -------------------------------------------- In connection to this change there are new Lua API functions: - fibaro:setSceneRunConfig(sceneID, runConfig), where runConfig is string that takes one of these three values: - TRIGGER_AND_MANUAL - MANUAL_ONLY - DISABLED Which will set given scene respectively to Automatic, Manual and Disabled mode. Any other value will set scene triggering mode to Automatic. - fibaro:getSceneRunConfig(sceneID) returns currently set value. Old functions: - fibaro:setSceneEnabled(sceneID, enabled) - fibaro:isSceneEnabled(sceneID) will keep backward compatibility and continue to work without change. 2
Shyrka973 Posté(e) le 27 juin 2016 Signaler Posté(e) le 27 juin 2016 Wireless update of Z-Wave devices: Je dois rêver Pincez-moi. 2
sebcbien Posté(e) le 27 juin 2016 Signaler Posté(e) le 27 juin 2016 Incroyable, le wireless update, 3 ans après (ou plus) leur annonce marketing.... Tiens, et les Qubino ? :-/ Et le last breached pour les capteurs Satel ? Testez bien la mise àjour des firmware des modules, je me demande juste combien seront "briqués"... Sent from my Note4 1
Jayce74 Posté(e) le 27 juin 2016 Signaler Posté(e) le 27 juin 2016 Juste pour le fun je vais la faire ce soir. On verra si la boite alu aimera le passage 4.080 à4.083, et combien de temps ca va tenir... Envoyé de mon iPhone en utilisant Tapatalk
Cmoi20 Posté(e) le 27 juin 2016 Signaler Posté(e) le 27 juin 2016 cool, ils ont corrigé le bug que j'avais : FIBARO Swipe imported by Gateway Connection not working properly il faut que je test cela. pour la mise a jour OTA, c'est une excellente nouvelle (si cela reste actif sur la prochaine stable).
BenjyNet Posté(e) le 27 juin 2016 Signaler Posté(e) le 27 juin 2016 Ah tiens les nouveaux triggers, c'est sympa ça !
PITP2 Posté(e) le 27 juin 2016 Signaler Posté(e) le 27 juin 2016 Mise à jour effectuée, bonne nouvelle les modules orphelins après exclusion ont disparu
anthonylegrec Posté(e) le 27 juin 2016 Signaler Posté(e) le 27 juin 2016 Quelqu'un a déjà fait le mise a jour? Pas de problème apparent? J'ai des problèmes de notification d'une scène en 4.082. Ils en parlent pas dans les bug fixed..
PITP2 Posté(e) le 27 juin 2016 Signaler Posté(e) le 27 juin 2016 PAs de problème apparent, update d'un FGMS en cours
Shyrka973 Posté(e) le 27 juin 2016 Signaler Posté(e) le 27 juin 2016 @PITP2 Il y a un Changelog par module ?
Lazer Posté(e) le 27 juin 2016 Signaler Posté(e) le 27 juin 2016 Sympa cette release Pour les MAJ OTA, apparemment ça fonctionne très bien depuis plusieurs mois cher les beta-testeurs, donc ça semble fiable. Espérons Sympa les nouveautés sur les scènes. Espérons que les plantages de VD et de HCServer (503) soient définitivement résolus.
Lazer Posté(e) le 27 juin 2016 Signaler Posté(e) le 27 juin 2016 - Wind speed available in weather conditions computed incorrectly - value too low Ce bug là je l'ai constaté. Cool si c'est résolu. - Z-Wave Weather templates lacking for devices of other manufacturers PITP2 tu testes avec le module Qubino Weather Station ? 1
PITP2 Posté(e) le 27 juin 2016 Signaler Posté(e) le 27 juin 2016 @shyrka, oui un change log par module
PITP2 Posté(e) le 27 juin 2016 Signaler Posté(e) le 27 juin 2016 @LAzer, chef oui chef mais pas tout de suite 1
Bobobull Posté(e) le 27 juin 2016 Signaler Posté(e) le 27 juin 2016 mise àjour installée 4.080 -> 4.083 et BIM 503 en progrès ...
PITP2 Posté(e) le 27 juin 2016 Signaler Posté(e) le 27 juin 2016 As tu purgé le cache de ton navigateur ?
BenjyNet Posté(e) le 27 juin 2016 Signaler Posté(e) le 27 juin 2016 Ils disent pas que les 503 ont disparu, ils disent juste qu'ils relancent les services derrière maintenant 3
anthonylegrec Posté(e) le 27 juin 2016 Signaler Posté(e) le 27 juin 2016 Je pense que je vais attendre quelques jours.. Voir si personne n'a des bugs
Lazer Posté(e) le 27 juin 2016 Signaler Posté(e) le 27 juin 2016 Le 27/06/2016 à 14:16, Bobobull a dit : mise àjour installée 4.080 -> 4.083 et BIM 503 en progrès ... toujours attendre un moment avant de se reconnecter, sinon c'est le 503 assuré car les services n'ont pas fini de redémarrer et d'effectuer les opérations post-migration
Bobobull Posté(e) le 27 juin 2016 Signaler Posté(e) le 27 juin 2016 Le 27/06/2016 à 14:17, PITP2 a dit : As tu purgé le cache de ton navigateur ? Oui, j'avais purgé le cache. Un petit reboot de la box et c'est reparti ... Voyons la suite
BenjyNet Posté(e) le 27 juin 2016 Signaler Posté(e) le 27 juin 2016 BON ! Est-ce que jeedom permet la mise àjour OTA.... hein ? hein ? hein ? Ça vous en bouche un coin ça... hein ???? 7
D-GK Posté(e) le 27 juin 2016 Signaler Posté(e) le 27 juin 2016 A croire que Fibaro aurait entendu le sondage qui avait été fait sur leur forum et pour lequel nous avions été plusieurs à se plaindre... Entre la mise en place d'un programme beta, la plainte des pubs mensongères (mise à jour OTA), on croirait presque que Fibaro nous écoute
Lazer Posté(e) le 27 juin 2016 Signaler Posté(e) le 27 juin 2016 non ça m'étonnerait, comme je le disais, ça fait plusieurs mois que ça fonctionne, et donc encore plus longtemps que c'est en développement. Perso je préfère qu'ils sortent la fonctionnalité quand ils sont sà»rs à 100% que ça fonctionne, plutôt que de la sortir à la va-vite et de bricker tous nos modules.
PITP2 Posté(e) le 27 juin 2016 Signaler Posté(e) le 27 juin 2016 MAJ Firmware OTA d'un FGMS => OK ça c'est fait 4
Bobobull Posté(e) le 27 juin 2016 Signaler Posté(e) le 27 juin 2016 Le 27/06/2016 à 14:24, PITP2 a dit : MAJ Firmware OTA d'un FGMS => OK ça c'est fait à moins de 2m de la box ou OSF et on verra bien ?
