Générateur D'id Pour Gea (Ou Autre Script)
Steven
Voici l'adaptation pour ceux qui comme moi sont restés en 3.600.
A placer dans un bouton d'un Virtual Device.
Récupération du résultat dans la fenêtre Debug du bouton.
local dead = true -- true pour exporter les devices morts
local excludeType = {"weather", "HC_user", "iOS_device"}
local excludeID = {}
-- Initiate connection with HC2
HC2 = Net.FHttp("127.0.0.1", 11111)
response ,status, errorCode = HC2:GET("/api/devices")
devicesJSon = json.decode(response)
local devices = {}
local names = {}
local rooms = {}
function addName(name, roomname)
	if (type(names[name]) == "nil") then
		names[name] = true
		return name
	else
		return addName(name.."_"..roomname, roomname)
function getRooms()
	response ,status, errorCode = HC2:GET("/api/rooms")
	roomsJSon = json.decode(response)
	rooms[0] = "inconnu"
	for k, v in ipairs(roomsJSon) do
		rooms[v.id] = v.name
function rename(name, roomname)
	local name = name:upper():gsub("[éêèë]", "E"):gsub("EE", "E"):gsub("[ûüù]", "U"):gsub("UU", "U"):gsub("[àâä]", "A"):gsub("AA", "A"):gsub("[öô]", "O"):gsub("OO", "O"):gsub("[îï]", "I"):gsub("II", "I"):gsub("%W", "_")
	local roomname = roomname:upper():gsub("[éêèë]", "E"):gsub("EE", "E"):gsub("[ûüù]", "U"):gsub("UU", "U"):gsub("[àâä]", "A"):gsub("AA", "A"):gsub("[öô]", "O"):gsub("OO", "O"):gsub("[îï]", "I"):gsub("II", "I"):gsub("%W", "_")
	return addName(name, roomname)
getRooms()
for k, v in pairs(devicesJSon) do
	local doit = (dead or not v.dead)
	if (doit) then
		for h, w in pairs(excludeType) do
			if (v.type == w) then
				doit = false
		if (doit) then
			for h, w in pairs(excludeID) do
				if (v.id == w) then
					doit = false
	if (doit) then
		table.insert(devices, v)
table.sort(devices, function(a, return a.roomID<b.roomID end)
local result = "<BR><BR>-- IDs générés le : " .. os.date("%d/%m/%y à%X")
local room = -1
local lastinfo = "";
result = result .. "<BR><BR>local id = {"
for k, v in ipairs(devices) do
	if (room ~= v.roomID) then
		room = v.roomID
		result = result .. "<BR>--"..rooms[v.roomID].."<BR>"
	lastinfo = rename(v.name, rooms[v.roomID])
	result = result .. lastinfo .. " = " .. v.id .. ", "
result = result .. "<BR>}"
result = result .. "<BR>"
result = result .. "<BR>-- usage :"
result = result .. "<BR>-- fibaro:getValue(id[\""..lastinfo .."\"], \"value\")"
result = result .. "<BR>-- GEA.add(id[\""..lastinfo .."\"], 30, \"\")"
-- print(result)
fibaro:debug(result)
  • Upvote 4
Salut Steven,
J'ai un petit bug qui doit venir de ma facon de nommer mes ID de Virtual DEVICE
Voila mon GEA en prod :
local id = {
        WP_HALOGENE = 14,
        VD_SMSFREE = 16,
        VD_JOUR_CHOME = 21,
         VD_MODE_MAISON = 24
Voila ce que me donne les generateur, :
 - il supprime mes "VD" qui sont avant le nom
 - me rajoute un E devant "JOUR_CHOME", ca sent l'encodage
 - manque un E à  SMS_FREE
local id = {
--Salle à  Manger
WP_HALOGENE = 14,
--Systeme-VD
VACANCES_SCOLAIRES = 20, CLOCK_SYNC = 12, JOUR_CHEOME = 21, METEOALERTE = 18, SMS_FRE = 16, MODE_MAISON = 24,
Merci merci ;-)
Sur base du script de Steven, j'ai adapté pour pouvoir stocker dans une variable globale et pouvoir utiliser un JSON.DECODE au lieu de faire un copier/coller des valeurs dans chaque script ou VD.
Donc, voici le script modifié à  mettre dans une scène pour mettre la variable globale idTable avec tous les ID et NOMS de device (testé en 4.040) :
%% globals
local hidden = false --- true pour exporter les devices cachés
local dead = false -- true pour exporter les devices morts
local excludeType = {"com.fibaro.zwaveDevice", "weather", "HC_user", "iOS_device", "com.fibaro.voipUser"}
local devicesJSon = api.get("/devices")
local devices = {}
local names = {}
local rooms = {}
		names[name] = true
		return name
	else
function getRooms()
	local roomsJSon = api.get("/rooms")
  local name = name:upper():gsub("[éêèà«]", "E"):gsub("EE", "E"):gsub("[à»à¼ù]", "U"):gsub("UU", "U"):gsub("[à âà¤]", "A"):gsub("AA", "A"):gsub("[à¶ô]", "O"):gsub("OO", "O"):gsub("[îà¯]", "I"):gsub("II", "I"):gsub("%W", "_")
  local roomname = roomname:upper():gsub("[éêèà«]", "E"):gsub("EE", "E"):gsub("[à»à¼ù]", "U"):gsub("UU", "U"):gsub("[à âà¤]", "A"):gsub("AA", "A"):gsub("[à¶ô]", "O"):gsub("OO", "O"):gsub("[îà¯]", "I"):gsub("II", "I"):gsub("%W", "_")
getRooms()
    local doit = (hidden or v.visible) and (dead or not v.dead)
  	if (doit) then
        		doit = false
    	if (doit) then
        		if (v.id == w) then
          			doit = false
  	if (doit) then
local result = "<BR><BR>-- IDs générés le : " .. os.date("%d/%m/%y à  %X")
local room = -1
resultVar = "{"
    	room = v.roomID
    resultVar = resultVar .. '"'..lastinfo .. '":' .. v.id .. ", "
resultVar = resultVar .. '"FIN":999 }'
print(result)
fibaro:setGlobal("idTable", resultVar)
Ensuite, il suffit de faire appel à  la variable globale et faire un décode :
local id=json.decode((fibaro:getGlobal('idTable')));
et faire appel à  son device par :
fibaro:getValue(id["NOM_DE_MON_DEVICE"], "value"))
Sympa ;-) super idee mais demande @steven tout de même..
Pas de variable à  créer dans le panneau ?
Sinon peut-on toujours appelé ses devices en id["device"] ?
Et que se passe-t-il sur la limitation de la longueur des VG ? ca passe tout de même ?
C'est un sujet qui a déjà  été discuter mainte fois sur ce forum, il n'y a pas de solution miracle pour stocker les ID de nos devices.
En effet, dans une VG, c'est une idée mais il y a 2 problèmes à  cela, et qui pour moi sont rédhibitoire :
  1. La limitation en nombre de caractère d'une VG
  2. Comment connaitre le nom id["NOM_DE_MON_DEVICE"]
En effet, dès que les id sont mis au format json dans une VG, il n'est plus possible de "voir" leur nom (limitation du panneau des variables) ou alors on doit créer un scène qui nous les affiche mais dans ce cas, cela perd un peu de son utilité.
Maintenant, a vous de voir selon vos habitudes, désires, ... perso, j'ai que 2 scénarios qui utilisent plus d'un ID donc j'ai pas vraiment d'expérience sur le sujet :)
Pour ma part, j'ai 3290 caractères et ça passe (nouveau en V4 ?).
Pour le nom de device, j'utilise ton output comme pense bête, comme ça je retouve facilement mes noms de device
@pepite : oui, il faut créer une variable globale dans le panneau
