Mise à  jour disponible
V4.022
  Citation
New Features
  Citation
Remote access is available for this version.
Resolved Issues
#0001513 RGBW custom created programs
#0001640 sceneActivation trigger doesn't seem to work
#0001681 Add / remove device continuous loop
#0001772 the remote control (KFOB2) we as a dimmer in Fibaro HomeCenter2 indicated
#0001898 Greenwave 6-socket plug shows as 7 switches
#0001924 beta 18 can not save scene with lux as a trigger (fibaro pir)
#0001931 HRT4 ASR UNIT not work in the Version 4.xxx
#0002000 Danfoss LC13
#0002032 Danfoss LC13 marked dead moments after status shows as "device is awake"
#0002081 FGRGBWM-441: Cannot turn on/off using mobile applications
Fixes for Z-Wave locks (Yale, FollowGood, Schlage)
Fixes for Z-Wave thermostats
Fixes for 3.x -> 4.x conversion process
Issue with backup compatibility
Known issues
Important! User Developed Plugins will be removed with this update. Please be sure you have your plugin source code.
Satel - adding plugin progress bar disappears during configuration. Please wait about 15 minutes before performing actions on Satel devices.
Devices Polling may not work properly - devices state in UI may be refreshed only after action taken.
Breached sensor with Arm Delay causes instant alarm after being armed
Data range selection in event panel doesn't work properly
Devices imported via Gateway Connection may have no icons
Gateway Connection status of dead device between master and slave controller may be different
Devices not properly configured on 3.X may not be converted properly
Reconfiguration may not work properly in some cases
On mobile clients devices may be visible in different categories than configured
Advanced settings for some imported devices may not work properly
Plugin for Sony TV will not work with newest Sony Firmware
Horstmann Thermostat HRT4-ZW higher battery usage in some cases
Doorlocks some functions may not work properly
-_- Apparemment, pas de correction de l'api du panneau de chauffage (methode PUT qui provoque un plantage) et pas d'intégration des modules Qubino. snif !!! (une sonde branché sur le secteur, moi, je dis, c'est un plus pour optimiser le chauffage)
Bon, qui se lance ? Trop tard pour moi pour tenter le coup, je ne me vois pas faire un recovery à  cette heure-ci et encore moins me priver de chauffage avec les températures actuelles. :P
Azer31
C'est bien marqué qu'il faut désinstaller les plugins Dev avant de faire la mise à  jour !
  Citation
Pas de changement de mon côté, toujours pas d'HEM,
Par contre quand je l'ai exclu puis inclu, j'ai ensuite appuyer sur valeur par défaut, et il m'a créé un autre module 278, sachant que j'ai une HEM2, et il me trouve 4 sondes ?, plus un module total...(voir image)
J'ai pas testé encore la télécommande KFOB2, en tout cas elle est resté en dimer
Mais lol, sa corrige certain de mes bugs.
Je viens de faire le recovery punaise.
Si quelqu'un peut me dire si la minimote fonctionne.
  • Upvote 2
Pour la défense de Azer31, le message d'alerte concernant les plugins n'étaient pas mis en avant comme lors du passage àla 4.021, mais c'est précisé, donc mieux que la beta d'avant. De toute façon, ça sera probablement le cas jusqu'àla version stable (le pourquoi, mystère, faut espérer que ça ne sera pas une habitude pour quand on devra on devra gérer les galères du passage au 5.xxx)
Alors...
Mon Secure SCS317 semble être supporté alors là , j'ai envie de les embrasser Fibaro !
En 4.021, depuis quelques jours, mon FGMS Salon ne remontait plus les lux alors que celui du couloir les remontait. En V4.022, tout semble rentrer dans l'ordre sans avoir besoin de réveiller les modules.
Mon Smoke Sensor par contre lui est en noeud mort mais laissons la nuit passée.
Toutes mes danfoss sont opérationnelles.
Mon RGB est aussi fonctionnel. En V4.021, il était en position ON sur l'interface alors que les leds étaient éteintes.
Super ... Netatmo toujours à  zéro, et je n'ai même plus les sondes de mon HEM, j'ai juste l'icone de la boite BR, c'est génial la 4.022
On va dire qu'il faut attendre une bonne nuit. :angry:
  Le 10/12/2014 à 20:14, Shad a dit :
De mon côté mes deux minimotes fonctionnent, mais elles fonctionnaient en 4.021
Par contre si ton netatmo ou un hem fonctionnent, j'échange... ;)
  Le 10/12/2014 à 20:06, Lionel57 a dit :
@ Yohan, j'admire ta bravoure...
Tant que mon chauffage fonctionne, c'est le principal. ;)
Le reste est du confort donc si ça plante, ce n'est pas la fin du monde.
@yohan,
quand mes lc13 ne fonctionnent plus àcause de la beta, je les désacouple.....pour assurer du chauffage et reviens au bon vieux thermostat
Il faudrait qu'ils changent la donne au niveau des Plugins, ça devient fatiguant de désinstaller puis de réinstaller toutes les màj. A croire qu'ils ne souhaitent pas que nous avancions sur les devs :(. Peut-être parce-que le store n'est pas encore en ligne !
Bah moi dès que je rajoute un plugin, le panneau de chauffage ne contrôle les modules liés de chauffage, seul les DANFOSS fonctionnent encore. On est plusieurs àavoir ce problème et bug accepté sur le bugtracker Fibaro.
Tu as des modules liés de chauffage ?
